Bending & Holding Veneer Wood
Mark Schaeffer
>Hi All-
I'm a pretty inexperienced carpenter, but I'm looking for the steps that are needed to bend and hold a small piece of veneer wood.
Specifically, I have some 2.5 x 8 " veneer wood pieces. They are 1/4 - 1/8" thick. I need to bend these into a circle (but the ends don't need to be connected, just come close) and have them stay this way.
You can see a sample in the picture that I uploaded.
What is the process to get veneer to do this? I've read about steaming wood, but was unsure if this would still allow it to hold its shape once it's dried.
I really appreciate any info that you can offer!!!
Re: Bending & Holding Veneer Wood
>Might I suggest "The Complete Manual of Wood Bending" by Lon Schleining. I've bent thick wood veneer for Shaker boxes using hot water. The ends are secured to each other and the base and bent around a form. I regularly steam bend thicker wood (~1" in thickness) and have it hold. I don't know how well your thin pieces will retain their shape unless they are secured.
Don Orr
>At first I thought you were trying to make your own coffee cup insulator, but then I looked closer at the left part of the photo and saw the bangle on her wrist. I'm no expert certainly, but bending the wood on a bias like the right picture might be difficult with a single piece of wood. Maybe think about doing it with a few thinner layers-think bent lamination-with the central layer grain perpendicular to the outer layers like plywood. Bent around a form and clamped and glued would hopefully have little springback.
Cool idea !
>I am not a coffee drinker and have never been in one of the high end coffee shops. Can you buy these things in Starbucks? Hmmm? How much of a market is there? How about laser engraving them?
You could make them out of thin veneer by laminating them. You could clamp them with a vacuum system system. Make a form or mandrel the size of the cup and wrap the veneer. Probably not necessary to have the vacuum press. You could wrap them with a heavy rubber strap, or make a jacket and clamp it on with strap clamps or hose clamps.
Now you point that out......
>Clearly I thought it was a coffee cup holder. Actually, you might sell more cup holders than bangles. How about a dual purpose one. Wear it until you buy coffee and keep from burning your hand. Then put it back on your wrist, nice and warm. Actually, everything I said still applies.
BobS
>These have been around for a couple years and they are supposed to be cup holders more than braclet/bangles. They are a bent lamination of several layers of veneer glued together in alternating directions made in a vacuum bag. Then cut and shaped.
Bob
Check June 09 FWW
Al Kapocius
>Fine Woodworking magazine, June 2009 article "The magic of hot-pipe bending" might work. Basically, it's the art of bending thin wood strips over a pipe section heated with a propane torch.
Al Kapocius
