Finishing oil, then glue?
Barry Rubenstein
>Once a finishing oil dries (Danish, Bull Oil, etc), is it ok to glue over the dried oil finish?
Barry Rubenstein
Re: Finishing oil, then glue?
>If I am "prefinishing" before assembly, I will shield the glue areas with tape. I prefer gluing wood to wood as opposed to finish to finish. Some of the finishes will come off of the surface of the wood.
My $0.02. YMMV.
Marv....... Northern California Lake Co.
>Barry,
I use BLO a lot and have glued after applying the oil, but, I found that I had to let it dry for days, like 4 days. Drying time of course depends on the weather or the temp. of the room where the BLO is drying. If I'm just going to apply a finish over the BLO, the drying time is much less, from 24 to 48 hours.
Marv
Howard Acheson
>The short answer is "no". Any drying oil will soak and seal the pores of wood. Waterbased adhesives must be able to be absorbed to develop full adhesion. Oils like "Danish Oil, Tung Oil Finish, etc. are mixtures of boiled linseed oil and varnish. So these products are even more effective sealers of the surface of the wood.
Tape, off or otherwise isolate, any surface that will be glued.
