THE WOODRAT IS BACK!
TV Stand opinions
TV Stand opinions
TV Stand opinions
Ray Carson - Lawrenceville, NJ
>Hello,
I'm currently building this corner TV stand for my home. Unfortunately, I'm usually building, fixing or cutting something for someone else, so this is a little bit more satisfying.
I'm moving along (slowly) and thought I'd post my SketchUp drawing for some opinions. Never too late to change something. The drawing was never really finished but it's more than I need.
The stand is 26" inches high, and measures just under 36" inches from the the wall out to the short flat sides parallel with the wall. I hope that was clear. The footprint cannot be any bigger due to restrictions from heat supply vents and door openings that are not shown in the drawing. The LCD flatscreen is a 42" set.
Other than being a little boring in design, what do you all think?
I'm no HC Sakman - see (Latest Work--Cherry & Rosewood EC (views: 859) -- HC Sakman will be @ Victoria LV APRIL 13th.! -- Wednesday, 8 April 2009, at 4:00 p.m. )
Thanks,
Ray
p.s. sorry bout the PIC, I tried to do my best with cropping, etc.
Re: TV Stand opinions
FWIW
>1. Put your media racks (left and right?) behind full height doors. Side doors can also be used to aid for ventilation by doing the panels in speaker cloth.
2. Consider extending your front doors to full height.
3. Loose the smoked glass as it will tend to interfere (somewhat) with your remotes' functions. There are rather nifty repeater kits you can buy to take the remote signals to each component, but last time I checked the good ones were pricey.
4. You need to plan for cooling of the enclosed e-tronics. If going by mere convection (like Chico), you need a low level "draw" and an upper level "exhaust" with the exhaust larger (at least twice) than the draw and perforated shelving for air flow.
4a. Consider a powered "silent" vent fan with a filter that is easy to access and clean.
howard
>I built an entertainment unit for a customer and worked with the company that was installing the audio components. They suggested not having any shelves where the components will be since the components were stackable and you need to think about air circulation, though an open back would probably suffice. Nice design, you may want to leave out that interior shelf, which will make room for more components.
Re: FWIW - Thanks Mark
>You made some valid points. I am concerned with ventilation and I had heard that smoked glass could give the infared signal problems.
I just printed your post and will keep your advice in mind.
Thanks again.
Ray
Re: TV Stand opinions - Hmmm
>Ventilation seems to be the concern here. Mark also mentioned it as you may have read. Okay then....top priority is venting.
Vent, vent, vent. Got it. :-) Thanks for commenting on the design too.
Thanks Howard,
Ray
