Homemade Belt Sander
Dave Tenney
>Here's a belt sander I finally got going this week. I started buying parts for this in 2006 after reading "The wonder of Knife Making" by Wayne Goddard.
It runs a 2x72 belt. The drive wheels are from Sun Ray http://www.sunray-inc.com/ It has a 3/4" shaft I bought at "Rural King" and had a buddy of mine put a key way in it. The body is made from an old Chatsworth computer rack we threw away at work. It's powered by an old Maytag motor. It could use something bigger, but this will do for now. I'm still working on the tool rest...What's on there now is just temporary.
I've got almost $200 bucks in the thing so far, but it seems to work pretty good. The belt tracks true and let me tell you, this thing will hog off metal like nobody's business.
Now I've just need to practice grinding bevels and I should be on my way! I have a 400 grit belt that may be useful for touching up chisels in the middle of a job...well see.
Dave Tenney
Re: Homemade Belt Sander
paul waddle
>great job,it that a spring on the back? pw
Don Evans
>Hey Dave:
It looks good also.
Cause you made it out of aluminum and the tempy tool rest also remember that rust and aluminum on a sanding belt (or grinding wheel) can and do cause serious flash fires.
I see the potential for you grinding some rusty metal to clean it and the belt slapping the tool rest. That can result in flash fire and it has happen with serious injury.
I would make the rest out of 1/4" steel plate, not aluminum.
Don
Dave Tenney
>Yeah...It's an old door spring I bought at a junk store.
Dave
Dave Tenney
>I didn't realize that could happen...Thanks for the advice!
I'm going to make the new rest out of steel.
Dave
