REAL MILK PAINT
Need some advice on worms & lumber
ryan in louisville
>I bought some walnut Sunday and stored it in my father-in-laws barn. He has some other wood in there and some of it has been attacked by some sort of worm (I haven't seen one) that bores teenie-tiny little tunnels all throught the wood, but only certain pieces, and none of them walnut. I won't be able to bring it home for at least a year or 2. I am wondering if I need to worry about these worms attacking my walnut, and if so, what do I need to do to stop them before they ruin my wood.
The wood is in Ohio right now, in case there is some sort of Ohio only worm.
Thanks,
Ryan
Re: Need some advice on worms & lumber
>In the old days they sprayed wood with Lindane (SP?). That protected it for a long time. Not sure you can get it anymore. Might be too hazardous.
Might want to go to WoodWeb and poke around and post the question.
The bugs sound like powder post beetles. There are at least two types. Anobiids and lyctids.
There are at least a dozen other insects that might infest wood. Don't think many or any of them particularly like walnut and especially don't like the heart wood. That's not to say that they won't eat it if they are hungry enough and happen to be in the neighborhood.
There are other chemicals you can try. One is Bora Care. A Borate dissolved in Glycol. The glycol helps it penetrate into the wood. I have no idea what the long term effect would be on the appearance of the walnut and what effect it might have on trying to finish the wood later. Might be better to soak the already affected wood in hopes of killing the insects and then find some sort of chemical that would sit on the surface of the walnut and get planed off later.
they will attack walnut
Bill Tindall, E.TN
>These critters find walnut sap wood as palatable as most any wood, though ash seems to set the standard for what they like best. Once they are in the sap wood they can move into the heart wood to a more limited extent. Once an invasion occurs they will completely destroy the sap wood. These statements are based on actual experience. I have lost hundreds of dollars of lumber to these bugs so now days I take no chances. I spray everything with insecticide that I intend to store.
You will get advice on using this or than but I can tell you from experience that a persistent insecticide works and stays working for at least 20 years.
Re: they will attack walnut
del schisler
>this is copy/paste from woodweb site I am against using any spray on the wood as, if you use a strong enough chemical, the chemical will still be there when the wood is planed. The planer dust and sanding dust will be serious hazards to human health. And if the wood is used for things that children might put into their mouths, you will have a serious problem as well.
At this point, you may be able to move the wood to another safe location, but if you wait very long, the walnut may also have PPBs and that is bad news. oak and ash being some others.
Sapwood vs hearthwood
Alex Grigoriev
>On a bit unrelated note.
Last month I torn down some drywall to rebuild frame for a window. The house was built in 1978. Reddish Douglas Fir studs (heartwood?) were virtually untouched by termites, while yellowish (sapwood?) were hollowed out very badly; leaving only like 4 mm outer shell.
why..............
Bill Tindall, E.TN
>You stated, "The planer dust and sanding dust will be serious hazards to human health. And if the wood is used for things that children might put into their mouths, you will have a serious problem as well. "
Why do you believe these statements to be true? I just got done spraying the peach trees with insecticide and I am wondering why I should be concerned about some kid chewing on a planed and finished table leg when it is widely accepted that spraying the same stuff on peaches is "safe". It does not necessarily follow that something that will kill a 5 milligram bug by interfering with its unique metabolic processes will have any effect on a 75 kilogram human. Until recently if your kid got lice his head was bathed in lindane, ditto for you dog and flea soap. One could suppose that this exposure was greater than table leg chewing or that the person spraying peach trees gets dosed greater than planing lumber with a proper dust control.
Not long ago much commercial lumber was dipped in a close relative of pentachlorophenol to prevent mold and bug attack. Anyone that is an "organic woodworker" will want to be sure they don't have any of this lumber still around. I trust the organic woodworker doesn't use a lawn service or pest control. Now these services worry me!
I don' t have any quibble with those that choose to avoid certain chemicals that they selectively (and mostly arbitrarily) avoid. But if you are going to claim that others will have adverse effects from using them then provide some data to justify the claim. Things aren't in fact "serious hazards" or cause "serious problems" just because you think they are and do.
Re: why.
del schisler
>this was cut/paste here from this site Not my openion I got this and posted I seen where he is in the know ?? Welcome to the Web Site of Gene Wengert
The Wood Doctor
Gene Wengert is President of The Wood Doctor's Rx, LLC, 2872 Charleston Drive, Madison, WI 53711-6502 and Professor Emeritus at the University of Wisconsin-Madison.
As a former professor and extension specialist at Virginia Tech and researcher at the US Forest Products Lab, Gene teaches over 30 practical wood processing classes and seminars a year for the wood products industry, including sawing, edging, grading, drying, machining and gluing.
Gene is the author of eight practical books and has published over 400 articles relating to the wood products industry.
To view additional information, just click on any of the links found in the left column of the page.
Gene Wengert, President
Phone: 608-271-4441
E-mail the Wood Doctor, Gene Wengert
*** OT Response ***
Howard Acheson
>Bill, I am unable to respond to your recent e-mail to me. You have some sort of block on your incoming e-mail and clicking on the "hot spot" generates an error message from your mail service.
Sorry, I don't have time to chase this any further.
Re: Sapwood vs northwood
>Alex, I have not seen this personally, but have been told that on the west coast it was a common practice to build houses supported on fir piers. the fir was resting on concrete or a stone ontheground. What kept the termites out of the fir was that they used old growth fir that had as many as 60 growth rings per inch. the termites could not get between the harder rings to eat the softer wood and left it alone. Probably saw that on one of the TV shows like This Old House Or Home Time. I Have personally seen many cases where the bugs selectively ate some pieces and not others. Oddly, they will by pass pine framing to eat oak flooring. There is no accounting for taste. I have seen very tight grained timber with what looked like road maps on the surface as if they were trying to nibble their way in.
Fred Davis
>West Coast, that rings a bell Barry, it being where I made my living building houses , so I guess you could call this first hand.
The post and beam system , with or without a box sill was and is a standard used more then any other with a concrete stem wall.
The post was generally , but not always Doug Fir , sometimes Redwood was used for it's bug resistance next to the ground .
If it was first growth wood , then it was a really old house , that wood not being available for construction use for many , many years.
The concrete piers were either precast blocks or sometimes cast monolithically with the Pier foundation concrete.
Before the advent of Pressure Treated Lumber , responsible builders either applied Copper Green (brand name of Copper salts), Creasote, or Penta (brand of Pentachlorophenol to the post , sometimes with a metal termite shield between the post and beam.
The "road map " appearence of the wood you mentioned that appeared to be caused by termites that couldn't get into the wood it's self , actully is a Dry wood Termite and that is all of the penetration they do, they they fly off to another structure without leaving behind a colony.
This Old House and other knockoff shows , unless actually moderated by Norm Abrams , sometimes could use a little more research on their editing.
FredD
