200+ woodworking book reviews
OT The dying little Bees
Wayne Carson
>They think they have found the problem for all the dying bees.
http://www.sciencedaily.com/releases/2009/04/090414084627.htm
Re: OT The dying little Bees
Re: OT The dying little Bees *LINK*
>Beekeepers have been treating for nosema with Fumagillin for quite some time - this makes for a healthier hive and has been proven to increase honey production. We treat in the fall and spring. The specific nosema strain mentioned in the article is newly imported - I first heard about it as a possible CCD (colony collapse disorder) candidate last summer.
BTW, commercial beekeepers are notorious about overstressing hives and either over- or under-medicating. A guy with 10 hives can pay better attention to each hive than the guy with 1000. Interestingly enough, CCD seems to only hit the commercial keepers.
http://www.betterbee.com/products.asp?dept=1518
Lee Schierer - McKean, PA
>Not entirely true. CCD has affected many hobby beekeepers as well, speaking from personal experience, we just don't make the news like a guy that loses 400+ hives in a couple of weeks.
Lee
Glad to hear it
Tony - Memphis
>We do our part to support the local population. Our cherry tree sounded like a hive a few weeks ago. Now, our dogwood sounds like a hive. In a month or two, the crepe myrtles will sound like hies. Some folks seem to be afraid of them, but with several trees and shrubs full of them, they nevere ever bother us. I built some orchard mason bee houses last year and they look like they were used. We have those big bees too that protect their turf. They sometimes get in your face, but they haven't bothered us too much. We'll have a patch of zinnias for them in a month or so too.
Tony
The Commercial Beekeepers, John
>May feel stung by implication. :<)
George
thanks, they are recovering here
Bill Tindall, E.TN
>the population is recovering here on the farm.. Three years ago we went from loads of bees to none detected. Last year there were some and this year the blooms have many again.
>Lee,
The bee expert at the Univ of TN told us that last summer there were no confirmed cases of the CCD in hobby hives in the state, although varied reports of losses which on inspection were attributed to some other cause. Maybe it's different elsewhere or perhaps things have changed since then.
The only people I know who lost hives were those who don't medicate as recommended (I know a few who think it's unnecessary and never medicate) and some who failed to feed. This past fall was horrible around here - due to the drought there was practically no late summer nectar flow and hives that were robbed in June/July could not recover. I fed my 4 hives 75 lbs of sugar before winter. One was a little weak in numbers over the winter and had me worried but they all seem to be strong today.
Re: thanks, they are recovering here
>Bill, do you have hives? When we moved to this farm I saw NO honeybees - all pollination was done by bumble bees, yellow jackets, and some tiny wasp-like insect. That changed only when I got hives. Now others in the area with gardens and fruit trees report seeing an abundance of bees.
If you were not seeing bees before and do now, I suspect someone in your area has begun keeping hives. I understand bees will typically fly 2 miles from the hive but will go up to 4 miles if necessary.
Without hobby beekeepers, many areas of the country would suffer. All evidence indicates that feral colonies (bee trees) do not last longer than a season or two at the most due to the verroa and tracheal mites, nosema, and other problems. Reports of feral colonies that have been in one place for years are suspected to be sequential occupations by swarms from domestic hives, each dying out and soon replaced with a new swarm which gives the appearance of continuous occupation.
Beekeeper costs...
David Hammelef
>My wife wrote an article about bee keepers awhile back, and we went and saw a hive and everything. Seemed kinda neat to me.
Wondering what the start up cost and continuing costs of that hobby are.
Re: Beekeeper costs...
>Costs: it depends! You could get started with a few hundred dollars or spend thousands. It would be hard to come up with a number since there are so many options. Once you have the bees and equipment, continuing costs are pretty low.
I think I spent a couple of thousand dollars to get started but I bought three complete hives, extra bee suits, etc.
You can save quite a bit on equipment costs if you build the hive bodies yourself. These are usually made of 4/4 white pine but I've made some from cedar. You DON'T want a heavier wood - I made one from yellow poplar once and it was way too heavy. You can also buy "kits" and put them together in a few minutes. Paint the outsides with exterior latex. Besides the basic boxes, you need a screened bottom "board" (base), and inner cover, and a cover. The covers are typically covered with thin sheet metal for durability. You could theoretically build frames (8-10 per box) but that would be a little crazy since they are so inexpensive and are fairly complex. Note that the sizes are standardized and the tolerances are fairly tight.
BTW, boxes come in three standardized depths: sometimes called "deeps", "Illinois", and "shallows". The current trend around here is to use two deeps for the brood boxes and shallows for the supers to collect honey. I usually add 2-4 supers but some use 10 or more!
You can often buy a complete hive, full of bees (less than $200 around here last year for used equipment) or for less money buy a hive box without bees and order a "package" of bees or buy a "split" from a local beekeeper. You can also get free bees by catching swarms in the spring - some people will pay for someone to remove a swarm from there yard! (Swarms can be very easy or very difficult to collect.)
You need a permanent place to put the hive(s) and stand - a level spot that gets the morning sun and has a bit of shade in the afternoon seems ideal. Stands can be made inexpensively - I use three pairs of concrete blocks with two 10' steel or wood (3x3 or 4x4) horizontal beams on top. A 10' stand provides comfortable working space for 2 or 3 hives. I put down plastic to help control weeds and cover with gravel. Getting the hives up off the ground a bit makes them easier to work on and a little less accessible to skunks. You need working space behind the hives. It's best to have a spot not visible from outside your property with some open space in front. Best not to place hives directly under trees. Avoid placing where bees have to immediately cross a sidewalk (people get annoyed) or where cars are parked (bees make droppings) when they exit the hive. Farmland is perfect, but people do successfully keep bees in urban areas with a little care (provided ordinances allow).
For associated equipment you need a minimum of four things: a hive tool to pry open boxes and frames (cheap), a smoker, a protective suit or jacket, and gloves. Some brave people who don't mind stings don't use protective equipment. I'm not sure of the current new prices but I think a full suit is $100-200. You will need some type of feeder (maybe $15). To collect honey you will need several "supers" - boxes full of frames which are placed on top of the hive with a "queen excluder" screen between. The queen excluder is inexpensive, perhaps $10 or so. Supers are inexpensive, especially if you build them yourself, and frames are also pretty cheap. Sorry I'm not up on the actual prices - I buy what I need and rarely pay attention to the cost. A google search for beekeeping supplies will give some real prices from suppliers such as Betterbee, Mann Lake, Dadant, etc.
Most beekeepers keep an extra empty hive or two around to catch swarms in the spring.
Other costs during the year are for medication (for mites and nosema), sugar for feeding if necessary, and perhaps requeening every few years. I fed 75 lbs of sugar to 4 hives this last fall and 25 lbs in the spring with medication. I don't remember the medication costs either but they are not excessive. In our area there are a few people who keep a lot of bees and buy medication in bulk and supply the local beekeepers at a good price.
To process honey you can do a small amount very inexpensively, rent or borrow an extractor, or spend a lot of money on equipment. At minimum you will need some containers such as 5-gal buckets, one with a valve for filling bottles (about $15 for the gate valve), and jars or bottles and lids.
The best thing to do is find a beekeeping club. You can meet other beekeepers, find local suppliers, and get advice on what to do and when for your area. For example, some areas of the country have to contend with aggressive "Africanized" bees, and areas in the frigid north may require different methods. There are also many excellent books and a wealth of info on the web. I think this is my 4th year keeping bees and there is still much to learn.
JKJ in East TN
