Wood Lamination Clamping
Sawman
>Has anyone got a lead on a method to clamp up wood laminations using a long tube and air? I cannot seem to findany sites dealing with this.
Thanks
Sawman
Thanks
Here's one *LINK*
Grant in Iowa
>Sawman,
Here is a guy who makes snowboards using air pressure inside a firehose.
Seems more elaborate to me than using vacuum pressure (which works GREAT by the way)...
FWIW,
Grant in Iowa
clamping with air pressure
Re: Wood Lamination Clamping
>Try the Vacuum Pressing sites. Don't know them myself but Joe Woodworker is one and their are several others like Vacuum Press or something. (I lost my bookmarks in a computer crash.)
There are at least two approaches. With Vacuum, you can put the lamination in a vacuum bag and use the vacuum pressure to pull them together. The second approach is to use positive pressure. Put them into a form with a deflated hose in the for with them and then inflate the hose to press them together. You would need a hose that is both tough and flexible. Vacuum can apply about 14 psi. With the right hose, you could apply more with air pressure, I suppose you could use both.
Imagine putting the pieces inside a tire with a inner tube and then inflating the tube to fifty psi.
I think if you have the right tube or hose, you can wind it around the form and then inflate the tube.
Jesse Cloud
>Even simpler, get an old inner tube and cut it into long strips. Tie one end tightly around the end of the lam/form then stretch and wrap until you reach the end, then tie tightly. This applies plenty of pressure to clamp during the glueup. We use this for 'freeform' lams that bend in 3 dimensions (think twisting legs under a glass table).
