Cutting a newel post....revisited
Ray Carson - Lawrenceville, NJ
>Hello,
A few weeks back I posted a question asking how to cut 1/4 out of a turned store bought newel post. I had a few ideas of my own and received some good advice from some members at WC. Here�s what I came up with.
I made a U-shaped trough or jig with three sides then placed the newel post inside. I placed two cross braces across the top for grab handles and to keep the box from collapsing. The trough was about 8 inches longer than the post in each direction. It�s made of 3/4 plywood. The kerf did close up slightly after removing the post after the first full depth cut. After removing the post and turning it 90 degrees and reinserting it, it opened up. The extra cut in the waste is from my forgetting to allow for the extra 3/4 for the plywood jig. I made 3 passes each side, measuring and raising the blade as I went along. I turned the saw off to measure, of course.
After the trial run on the first post I proceeding with the other three, cutting one side on all the posts to full depth. Repeated the above steps and ran the three again. Worked pretty good.
I know what I did isn�t rocket science, but I thought I�d post this anyway. Maybe it could help someone in the future.
Thanks for looking.
Ray
Re: Cutting a newel post....revisited
paul waddle
>Thats a clever jig! Why did you want to cut it? pw
Re:Reason for cutting
>Hello Paul,
My brother is re-doing his kitchen and re-using some of the kitchen cabinets. He has a U-shaped island of which has two lazy susans in the corners of the U. Believe it or not, the one lazy susan was cut out or removed and someone placed the ELECTRIC hot water heater under the cabinet in it's place. We know there was two lazy susan's judging by the mount for the revolving shelf that was scraping the top of the water heater.
The water heater has since been relocated based on a code violation.
Anyway....
He's removing the back of the cabinets at these locations, re-placing them with a new back at a 45 degree angle thus creating a counter overhang. These two corners are receiving a newel post leg support and will provide "bar/counter seating".
The remaining 4 corners are getting these 3/4 posts that I cut applied to them. My brother is trying to get a country table type of look by applying the newel posts to the island. It actually looks pretty good. It's all naturally finished oak. No stain.
I hope I explained this well enough.
Ray
Pictures?
Dan Donaldson
>Sounds like it would make a good picture.
Re: Pictures? - Okay Dan.
>Right now my brothers kitchen looks like a war zone. It's a work in progress. As he completes things a little more, I'll post the PICS for the WC crew if you think it's worth it.
Ray
Dan Donaldson
>Don't know about others, but this sounds like something that I would like to see. I definitely think it is worth it.
Glad it worked out, Ray
Ellis Walentine, Host
>The only thing that bothers me about your jig is that it looks like a kickback waiting to happen. Your newel post is captive between two side walls, so when you make the final cut, the off fall has nowhere to go and it is constrained between the blade and the side wall. Under those conditions, I would recommend nailing a stop behind the cutout piece to push it past the blade after it becomes a free agent.
I still favor the method of just putting a square piece of wood on the narrower end and running it in an auxiliary L-shaped fence.
Re: Captive box and kickback
>Hey Ellis,
Yeah......I had a very small issue with the piece lifting up in the jig and yes the cutoff was jittering inside the jig. I actually made a dry run...saw turned off, blade below the table surface and so forth to see how my body needed to move during the process. I also marked the starting and back edge of the blade on the table so that I knew where my hands were going to be in relationship to the blade. I also thought about how I was going to shut down the saw at the end of the cut. The kids and wife were home and I told them to STAY AWAY and DO NOT come downstairs and talk to me while I was cutting these.
I also asked a co-worker/woodworker his thoughts and he also thought an L-shaped fence would do the trick. There's always more than one way to skin a cat I guess.
The advice from everyone here at WC is always appreciated. One thing for sure, I won't be doing a lot of these. :-)
Thank you,
Ray
