Lye Neutralization on Cherry
>Good Afternoon Friends
Our new queen size headboard and footboard to the Master Bedroom Suite are delaying completion of the project. The cherry uased to construct it did not color as did the cherry used in all other bedroom furniture items. I stripped/sanded off the shellac seal coat and am now back to raw wood, which I am trying to oxydize in strong sunlight for several days, if and when Spring finally shows up here in the Philadelphia area.
I experimented on samples of cherry from the lot the bed was made from, applying both potassium dichromate and lye solutions in various strengths. I like one of the lyed samples, because it matches the other furniture so well. If its necessary to commit to lye, I wonder if the surfaces must be neutralized after the lye is applied. I went on to finish the sample directly after the lye application had dried. It looks okay now that its finished, but it is a small area by comparison. Please comment. Thanks.
George
Re: Lye Neutralization on Cherry
>Little white vinegar and water should do the trick to gitchu back neutral. Don't go the citrus route because citric tends to bleach. I would not leave un-neutralized caustic in the wood.
Paul Kramer
Paul Kramer
>Colonel,
I've had good success with a 1% solution. I have not needed to neutralize that. I have just flooded the area with distilled water afterward with good results. The tannins in the wood are really tannic acid -- so in a sense -- you are neutralizing that.
HTH,
Paul
