Happy Easter and OT - electrical question
north of the border
>I have a hand held light for video camera and it works when I plug it in the 12 V 10 amp cigarette lighter socket in my car. Is there way I can use it indoor with a power adapter plugged in a wall electrical socket? If so, what kind of adapter do I need? I don';t seem to find an adapter with 12 V and 10 Amp. Most are 2 Amp or less. Thanks.
Re: Happy Easter and OT - electrical question
Dan Donaldson
>I would check with the light mfg. and see if they have an adapter for it. If no luck there, then see if there is a tag on the light that tells you how much it actually draws. My guess is that it may be a bit difficult to get a power adapter with the requisite power capability unless it is from the mfg.
Rod Peterson -- Ormond Beach
>The "12V 10A" socket only describes what it's capable of delivering—as Dan says, you have to know what the light draws before you can make a determination of what kind of wall widget, if any, you'll be able to use. See if there's a description of the replacement bulb somewhere. That information (voltage and wattage) and a little math will give you your answer.
Rod
OT - electrical question More info
north of the border
>Thanks to both of you. I took out the light bulb (and broke it!) and the marking said 12 V 100 W. I have some spare 12 V 20W halogen bulbs. Any idea what adapter I need for the 100 W and 20 W light bulbs respectively?
OT - electrical question REPORT
north of the border
>The lamp works well with a 20 W halogen light bulb on an adapter rated 16vDC, 0.9 A. Any idea what I would need for a 100 W halogen light bulb?
Jason Roehl in Lafayette, IN
Re: OT - electrical question REPORT
>Well, considering the DC plug is rated at 12V and 10A, which is 120W, that's what you're going to need. 100W to power the light bulb, and probably about 20W of heat loss before the light bulb (which loses a bunch of that 100W to heat instead of light).
Jason
Jim DeLaney, Austintown, Ohio
>100 watts @ 12 volts equalls an 8.33 amp draw, so a ten amp power supply is what's needed.
The cheapest - and klutziest - solution that comes to mind would be a Malibu light transformer/timer pack. HD has a 121 watt one for aroung thirty bucks.
Next klutziest one would be a battery charger, capable of a ten amp charge. Probably more costly - and less output regulated - than the Malibu setup.
Other than that, probably a more costly low voltage halogen lighting transformer - likely into a hundred bucks for that.
Other than that...???
Jim D.
Re: OT - electrical question More info
>Well, the math says a supply delivering 8.33 amps is needed. That's assuming a fairly short cord, because as Jason hints at, I²R losses will start to really drop the voltage at 8A (and DC), and you don't have that many volts to drop when you're starting at 12.
Since you're talking about a wall widget anyway and not true portable work, you might want to think about an actual 12V power supply—something on the order of 15A—because they often rate them at "intermittent" service, which is fine for two way radios, but lights aren't intermittent, they're continuous.
And by the way, don't think you're going to get away with 18 or 20 gauge wire, either, unless it's really short and your light isn't on long. A minimum of 16 gauge wire, I believe, would be wise, and there are lots of extension cords of that size you could modify. A 15 or 25 footer would be about right. You may have to fiddle to fit it into automotive DC connectors but if you were to do a conversion of your lash up to Anderson PowerPole connectors you could even use bigger wire.
The foregoing applies to your 100W light—the 20s are duck soup. 2A should do it.
We ham radio guys fiddle a lot with 12V stuff, but rarely with wall widgets. My HF radio draws 20 amps on transmit, and I have a VHF amplifier that draws 25.
Rod
Re: Thanks all. The HD solution sounds practical
north of the border
Try a Jump Starter Box *LINK*
A Wright
>I have two "jump start" boxes for car batteries, and both have a cigarette lighter plug built-in. You can plug the light into the box and then if you need it long enough that it will run down the battery you can plug the box into the wall.
Even if you dont have one, it might be more useful to buy the jump starter than buying a Malibu converter that you probably wont ever need again
http://www.amazon.com/Black-Decker-VEC010BD-Start-Starter/dp/B000E1HAIK/ref=sr_1_9?ie=UTF8&s=automotive&qid=1239421625&sr=1-9
Re: Try a Jump Starter Box
>This looks like an neat easy solution to me. These things are available all over the map with all kinds of features, such as a radio and work lights. Might serve a very useful purpose if you carry it in your car. What I don't know about them is whether the voltage output is accurate enough for your purpose, but sense your light is made to plugged into a car, it should be.
Re: Try a Jump Starter Box - Thanx
north of the border
