OT - Can the code for a garage door opener be chan
T Rex
>OT - Can the code for a garage door opener be changed?
Re: OT - Can the code for a garage door opener be chan
Al Goldstein
>Yes. I don't remember exactly how to do it, but the instructions are in the owner's manual. You press a button on the main unit and it randomly changes the code. Then there is a procedure for transferring the new code to the remotes. It is easy once you know how to do it.
Re: OT - Ditto what Al said.
Ray Carson - Lawrenceville, NJ
>It's similar for most openers but a little different based on manufacturers. I would refer to the owner's manual.
If you don't have one or can't find it, look online for "help" info. for your specific make and model. Most manufacturers have this info. on their websites. Look for an "800" number and try calling the manufacturer.
What make and model do you have? Maybe someone here at WC has the same brand and can assist you. I have two LYNX-Pro 3/4 hp openers.
Ray
Dave Bair, Eaton Rapids, MI
>Most modern openers have a "rolling" code that changes constantly. Usually, you just use the portable sending unit in close proximity to the opener to sync them.
Yes, the REALLY old ones...
Neal in San Jose
>My house was built in '63 and the opener is original equipment. It has a row of miniature switches - maybe 8 - on the control unit inside a removable panel. You set a sequence of +, - or 0 on those switches and then set the same sequence on a similar set of switches inside your remote. Make sure your are looking at the remote right side up, or all of your switches will be in the opposite position you think they are. DAMHIKT
T Rex
>Thanks, Guys, for your help.
I'll look for the manual and look at the unit to see if there are switches in it.
Happy Easter,
T Rex
Tom Rex
>Gentlemen;
Once again you have shown that the members of this forum are the greatest in helping others and have a gerat wealth of knowledge.
I got the instruction manual out and right there it told me how to change the code. Took longer to get the step ladder than it did to chnage the code.
Thanks again for your help,
Tom
One other place to look
Lee Schierer - Mckean, PA
>My mother had to get a new battery for her opener which required resetting the code and the procedure for setting the new code was right on the side of the opener motor housing. It worked first time for hers.
Lee
