Breadboard ends, How you do it?
Alan Tolchinsky
>Hi All, I'm going to be doing this on a small table top about 13x12". How do you cut the tongue? Router table or table saw? I'd appreciate a description of how you do this whole process. Thanks!
Re: Breadboard ends, How you do it?
>I have a "sliding" clamping jig that fits on my table saw fence. I will clamp the table vertically to the jig and cut one side of the "tenon". I then rotate it and cut the other side. I then make the cuts with the table top flat on the saw.
For larger table tops, I use my clamp guide and a router.
Re: Breadboard ends, How you do it? *LINK*
Jim Dillon
>Alan,
Neither. I built a small end table roughly that size last summer with breadboard ends and used accurately placed loose tenons. This job was made MUCH easier with my new Domino, but could be done with a router jig to hold the board. The center loose tenon is glued while the two outside tenons are not glued, but placed into mortises slightly bigger than the tenon. Five years ago, on a larger tabletop, I used a TS, then fine-tuned with a shoulder plane. If I had to do that one over in a conventional manner, I would probably use the router technique as manipulating a large heavy tabletop on the TS is cumbersome. In a less conventional manner, today I would use loose tenons, whose size and number would depend on the size and thickness of the tabletop.
Here is a relatively recent WC thread on breadboards. In addition to the references I gave in that thread, I've recently found another that is quite good: Scott Gibson, "Build a Sofa Table", FWW, April 2003, No. 162, pp 74-79. Mr Gibson uses an easily constructed router jig to cut the tenons. Hope this helps.
Jim
WC Breadboard Construction
Breadboard Loose Tenon
Jim Dillon
>Alan,
Found this pic made while I was constructing the G&G style end table.
Jim
Re: Breadboard Loose Tenon
Jim Dillon
>Alan,
In looking at the picture, I remember I made a "mistake" by cutting the elongated mortise in the breadboard, in addition to the tabletop. Didn't really need the elongated mortise in the breadboard, just in the tabletop. Guess I got carried away in using my new tool ;-).
Jim
Alan Tolchinsky
>Jim, Thanks so much for all that info. I use loose tenons a lot but never thought of using them for this. I'll give it a try but first I'll read your linked info. I really appreciate the help.
Best Regards, Alan
Old School
>Alan,
I've done several breadboarded tables, and believe in putting as much of the main section into the crosspiece as possible. I cut the tenon in a three-section haunched "E" style that projects to within 1" from the outside surface of the crosspiece. The tenon is at least 3/8" thick for a 3/4" top (1/2" for 1"). The reason for this is that people (especially younger ones) have a habit of sitting on tables so I want the full strength of the main top for that support. I cut the tenons with a router and a planing bit. The mortises are cut with either a bench mortiser or horizontal router table using a spiral up-cut bit. Pic is of an ash trestle coffee table finished with General Enduro with cross-linker. Pic 2 is a combination cherry and walnut done in Target waterborne lacquer
No. 2
