?? Milling fresh cut lumber??
Edward McCormack
>Afternoon everyone. My neighbor just cut down an oak and apple tree today. He saved me some 5' pieces. WHat do i do with them???? I would like to use them @some point. Do i paint the ends of the logs and wait a few years? Can i mill them on my band saw? Or should i cut them into 2" thick slabs with a chain saw. There is also on oak tree in my backyard with a 3' growth on the side, would love to do something with that also. The oak tree was dead but very wet and the apple tree was still alive. Thanks in advance.
Ed
Re: ?? Milling fresh cut lumber??
>Ed, you don't say what the diameter of the pieces is.
There is no pracitical way to preserve them in log form. If you paint or seal the ends they will keep a little longer than if you don't, but that's measured in days or weeks, not years. You could submerge them under water and they would keep for a few months, unless the water were really deep and cold. So, you probably need to saw them into planks. That can be done with a chainsaw, but its tough to do and dangerous. There are chainsaw mills around, but it may not be worth buying one for two logs.
If they have any size/weight to them it would be tough to do it on a regular bandsaw.
You might do a Google search for Woodmizer. They sell bandsaw mills and keep a record of their owners that might be willing to come to your place and saw them for you, or if you can haul them, you could take them to the mill.
The growth on the side of the tree might be a burl. It might be interesting, but AS I posted down below, I would be reluctant to remove a sizable burl from a tree that I wanted to stay alive and healthy. Post a picture and we might be able to offer more help.
Edward McCormack
>The oak is agout 12" the apple is about 8". The growth is on a tree that is going to be taken down in a few months. You said it might be tough to do on a regular band saw, but it can be done? I could cut them into more managable pieces. Will the sap ruin my blade?
Glenn Madsen near San Francisco
>You can certainly do the 8" apple. 12" oak will depend on your bandsaw, and your setup, and how many helpers you have available. 5' of fresh, wet oak is pretty heavy to lift.
I tried to save some birch in a 36" long log form, but found this week that I had lost it to bugs. Should have cut it earlier, even though I just figured out what I needed it for.
Sap can be cleaned from the bandsaw blade pretty easily. Make sure the machine is unplugged, and advance the blade by hand. Or just resaw some old scrap wood, and let it clean the blade that way.
>Ed,
Woodturners cut green wood all the time with shop bandsaws. Use a course-toothed blade, usually 3-tpi or less. I use a 1.5 tpi band on my 18" Rikon. For years I used 3 or 4 tpi blades on my 14" Delta with a riser block to section up to 12" pieces, but it was pretty slow going.
Woodturners usually make chunks for bowls, etc., which is a lot easier than cutting slabs. If you want to mill a log section into boards or slabs on a shop bandsaw, you will have to devise a way to hold the log tightly or face a disaster. I've seen milling sled plans in books and on the internet or you can cobble something together with plywood or scrap lumber. However, I think 5' log would be a real pain and perhaps impractical to mill like this due to the weight and size.
You can mill with a chainsaw either by hand (tricky) or with an inexpensive attachment. It is slow, requires a special ripping chain for best results, and will waste a LOT of wood with the thick chainsaw kerf.
As someone mentioned, the easiest thing is to get someone with a bandsaw mill to slice up your log. If you happen to live in East TN, bring the log here and I'll be glad to saw it for you - it will only take a few minutes. Woodmizer keeps a list of people willing to saw for others - give them a call for names near you. Some people charge by the board foot and some will saw on shares, for example, you bring the log and help and go home with 1/2 the lumber.
If you coat the ends of the log with anchorseal, you may minimize cracking if it will be a while before you get it milled, which should be as soon as possible for best results. The boards or slabs will have to be dried properly. Leaving the log unmilled for even years will do nothing useful - there is no way it will dry inside and the ends will probably crack severely.
