"Art Project" table
"Art Project" table
"Art Project" table
Bill Tindall, E.TN
>This table started out to be a table for the porch. We eat breakfast out here when it gets about 50 degrees. Reminds me of camping if its cold, that's a good thing.
Well it turned into an art project and will wind up in daughter's house. It is white oak and finished natural with Target EM 9300 Urethane Polycarbonate finish (sprayed). It is a water white non-yellowing indoor/outdoor finish (its was supposed to go out doors).
Re: "Art Project" table
Thanks......
Bill Tindall, E.TN
>to all the people at Wood Central that offered help in design.
Re: "Art Project" table - Oooo!!!
Ray Carson - Lawrenceville, NJ
>That's mighty purdy Bill. I really like the fan effect on the top and how well the grain appears to be book-matched.
Very nice!!
Ray
Re: It is book matched - Umm da?
>Hey Bill,
I guess that was a dumb thing to say wasn't it. :-) Honestly, I just thought you did a REALLY good job of finding matching pieces.
How did you achieve the book matched top? Is it veneer or is it thicker stock re-sawn into halves. How thick is the center pieces forming the "fan"?
Regardless, I love the white oak. The legs are nicely done too.
Ray
Nice!
Tony - Memphis
>Looks deceptively simple, but I know it wasn't/isn't. Really nice work Bill. Nice wood too.
Tony
>That's really nice Bill. Obviously you should have done like norm and made two of them. Now you have start over and make one for yourself. Flattering that your daughter took it away from you.
A question, are the legs curved? Inside and out or just inside? Or do I need to adjust my monitor again?
How book match was done
Bill Tindall, E.TN
>First I planed a quartered board that had flake that arced. Then I laid the pattern pieces on the board to arrange the flakes to flare out as you see them. After cutting out the pattern piece I split it with band saw. Fitting it all together was interesting. The inset top is about 1/2" thick
Alan Young
I think that is an innovative design.
Alan Young
>The fan motif is a commonplace feature in furniture but you have displayed it a fresh and attractive setting. And as Tony said- a more complicated piece to execute than might appear. Bravo.
Alan
Re: How book match was done - Thanks Bill.
$1,200 at Regis Bernard ?
steve mackay
Re: Top PIC
Bill White
>That's a winner old man.
Bill
Dale Lenz
Dale Lenz
>NICE looking table, Bill. Assumed you tendoned the fan pieces into the table's top frame. Did you pin the fan pieces from the bottom or just glue. The table is very "clean" looking, I very much like it.
tennons and pins and more assembly details
Bill Tindall, E.TN
>Assembly was a nightmare. Tiny errors multiplied across the spaces between the curved pieces resulted in huge gaps at the ends upon assembly. So, I made an outline of the frame on plywood. Then as I fit the "puzzle" pieces to this frame outline I temporarily braded the pieces in place on the plywood. Upon completion I lay the dry fit frame over the "puzzle" and scribed the frame outline onto the puzzle pieces. Then I cut the tenons and chiseled to the scribe line on each piece. In this way I knew it would all fit perfect upon assembly into the frame. However, I had to loosen the tenons so the puzzle pieces could be slid around after they were set into the frame so as to adjust the small spaces between them. When all was well I permanently braded the pieces to the frame.
Mike Caldwell
>Very nice work. Congratulations.
Mike
Re: Top PIC
HC Sakman --- Victoria,BC. CANADA
>I really like the top Bill, nice job.
Chico...
