REAL MILK PAINT
Exploding ebony - is it me?
Doug in Denver
>So I bought a chunk of Gaboon Ebony at Rockler to use for inlays. It's about 10" x 4" x 1". If any of you have seen how they sell it, it is encased in a thick layer of wax on all sides. Obvioulsy I can't use it that way, and it would take 500 years for any residual moisture to escape it. So I used the jointer to remove the wax, leaving it on the ends only. It was cool to the touch, a sure sign of high moisture content. Within a couple days it started cracking like crazy. By the time it's done I will have nothing big enough to use. I can't imagine anything else I could have done differently, but thought I'd ask.
Re: Exploding ebony - is it me?
Kirk (KC) Constable
>I bought a 'lifetime' supply of 1x1x12 ebony pieces, also waxy, at Woodcraft many years ago, and resaw them down into 1/4 and 3/8 square strips that I cut plugs from. Never had a lick of trouble doing that.
kc
GalenV in Iowa
>I won a piece 2 x 2 x 3 at a seminar drawing that was wax coated. I just scraped the wax off to mark centers with the intent of turning but then came back the next day and you would be lucky to make toothpicks from the pieces.
It was almost like it had exploded.
Must have been why it was donated to the drawing.
Galen
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I would suggest that if you know or think that it is wet / green, that you might put it in a paper bag to slow down the loss of moisture from the surface faster than it can move out of the middle of the core. Leave the end-grain coated as long as you can.
paul waddle
>No, its not you,its the trapped moisture as you suggest. I would(next time) split it with the bandsaw,and leave the ends and sides coated. I'm no authority but I've done some big branches that the ice storm broke in Feb like that,they seem to be curing without cracks. Sorry,but sh...t happens. You won't find dried wood with wax on it,so beware. dmt.
