We value your privacy.
>I forgot to remove hose from sillcock ovre winter. No leak in the house, fortunately. When I turn the water on, water comes out the spigot, as usual, but when I attach the hose, water also spouts out of a 'valve' on top of the sillcock. Is this repairable? What is the function of this 'valve'. My sillcock looks like the one in the link, but probably is a different brand. The 'valve' I am talking about is the one on top, with the white cap.
>That device on top is a Syphon breaker, there should be two small phillips screws on top of the "dome" shaped piece take those out, pull the guts out, take it to a good plumbing parts store and they should be able to fix you up. That may not be the only problem, but if you don't see any splits in the sillcock you should be good to go.
glc
Re: OT - Question about frost-proof sillcock *LINK*
>Gary is right. As a Home Inspector I find these ruined by freezing fairly frequently. If you are really lucky you will be able to repair it as Gary described. OTOH, what I often find is that the tube back into the wall has split. The test is to put a stopper/cap on the hose bib and turn the faucet on and see if you can hear it hissing inside the wall. In your case, you might have to repair the leak in the vacuum breaker to be able to tell if the tube/body is also leaking. Might be a double whammy.
>I have always disconnected hose in past, but failed to this year. One more sign of old age, I guess. Thanks for info; I hope I can get it fixed without plumber.
>I forgot to remove a hose, too. The "freeze-proof" spigot relies on water draining out of the long tube; the actual shutoff washer is at the far back, interior of the tube. The attached hose kept the water from draining out of the tube. When old man winter blew in with 0 degree temps, the water trapped in the tube froze, splitting the tube inside the house. Fortunately, I found the leak quickly when I turned the spigot on in the spring...the water sprayed out into the basement and I heard the spray right away. No damage to anything but the tube. I just lightly pounded the tubing back together and soldered the split like you normally would with any copper pipe. Not pretty, but it has held for 15+ years now.
And I don't forget anymore to remove hoses when cold weather rolls around.
