Cocobolo ... Color ... Finish ??
Joe Burke
>I'm using cocobolo for the first time, and while I've answered almost every question through research, I still have one question unanswered.
So here we go.
Once processed the lumber I have is a vivid orange/purple mixture. I understand why, and I understand that in time it'll turn back to that pretty reddish, brownish rust color that we're all after. I guess the two questions (yeah, I added one) are ... How long will the change take? Will finish slow or stop the change in color?
I know that the answer to "how long" is, "it depends". However, I'm hoping someone can give a ballpark answer.
As far as finish goes, what I'm making will get shot with a vinyl sealer and lacquer of some sort. Will the color change proceed regardless of finish, or do I need to wait and let some color develop before I shoot my sealer? That last question would apply to any exotic subject to wild color swings.
I'm looking for info to provide the client with answers. Such as ..."The two week delay is so the wood will oxidize and change color, and even then it'll continue to darken with age."
So don't freak out if you see some purple.
Re: Cocobolo ... Color ... Finish ??
>Here's a cocobolo table that I made around '86, which gets a fair amount of sun, more on one side than the other. Rather than it getting darker, the sun has bleached it. In a low light situation, I wouldn't expect much color change.
The finish is multiple coats of old fashioned one-part solvent based acrylic auto lacquer that was rubbed out with auto polishing compound. No sealer or undercoat, but pre-washed with acetone.
Good luck
Clint
>I use a lot of cocobolo for woodturning. (Sorry, can't answer the specific question you asked.) I've had good luck with shellac-based finishes, but once I put Watco oil on a piece and shellac friction polish on a second piece at the same time. The one with oil started changing quickly and in a year it was almost as black as ebony. The oil was applied on the lathe so the heat of friction may have contributed to the problem. Other pieces have changed color a bit in a few months but seem stable even a few years later. However, I suspect cocobolo varies considerably like other woods.
I did notice when cutting up some large slabs and blocks of very old cocobolo that the outside is often very dark brown, almost like walnut, and the brown extends for some distance into the center. I assume this is from slow oxidation, but who knows, there may be other environmental reasons.
