Dumb burl veneer question
Jim in N. Va.
>I'm planning on building a William and Mary highboy. Many of the high end originals had drawer fronts veneered with walnut burl. (Which I assume was sawn.) Unfortunately, I have only been able to find rotary cut walnut burl veneer for sale. Obviously, for normal wood there is a huge difference between sliced or sawn veneer and rotary cut. But is the same true for burl?
Re: Dumb burl veneer question
>I don't actually know the answer to your question. I would assume that all the veneer today is sliced, not sawn, and either rotary sliced or plain sliced. My understanding is that they often rotary slice burls to enlarge the size of the pieces.
I think the real answer is that for a project of this magnitude and quality, you would eight hand pick the veneer in person or at the very least, select it from photographs of individual pieces. Any reputable dealer in veneer of this quality should be able to accommodate you either way. You will want pieces that are from the same burl and sequentially matched so that you can do book matching, etc. Buy plenty when you buy it. Any you buy later probably won't match unless they still have some from the same burl. Burls are highly variable, some are spectacular and others not so much, so shop around and find some that appeals to you and suits your project.
Don't think so.......
Bill Tindall, E.TN
>Why do you think the burl is rotary cut? It makes no sense to me. No veneer for "high end" applications is rotary cut. It, and the burl, will be sliced in the same pattern as if it had been sawed, just thinner and with no sawdust.
As you may know , such veneer will have a "front" and "back" side and it may be important which side is out, or if you are book matching you will just have to live with this situation.
Re: Dumb burl veneer question *LINK*
Bill Earl
>I think what you are referring to is half-round slicing. Sort of between a flat and a rotary cut. (See link)
At any rate, the figure is the important thing and no two burls are alike. Find a good supplier, either locally or one with good photos of the veneers. (I've had good luck with www.veneersupplies.com)
Find a figure you like and buy more than you think you need - because you'll never match it if you mess up a sheet.
http://www.veneernet.com/halfround.html
RKnapp
>You might try talking to :
http://www.berkshireveneer.com/
or
http://www.certainlywood.com/
They should be able to help you out
not necessarily true
Thomas S Stockton
>Bill
There are actually a couple of pretty common veneers that are rotary cut in the high end market. The two that come to mind are birds-eye maple and kewazinga which is a rotary cut bubinga and sometimes is sold as having a waterfall figure. As another person posted the reason to rotary cut is to get wider bigger pieces which sell for a lot more money than small pieces.
To answer the original question I don't think that using a rotary cut burl should be a problem, the most important thing is to find a flitch that looks good and fits how you think it should look. As another poster said, don't buy without seeing a picture of the burl.
I've been getting most my veneer from Berkshire veneers and am very happy and the owner Ben is a good guy to deal with. Another source that has come highly recommended is b & b rare woods. You also can't go wrong with Certainlywood.
B & B is at www.wood-veneers.com and someone else posted Berkshires and certainlywoods web site.
Tom
Think so.......
HC Sakman will WALK IN LeeValley APRIL 13.!!!!
>Hi Bill,
Larger sizes of burl veneers are usually rotary cut, including walnut. They are often looking different than the "classic" walnut burl look. Many of them are actually curly and/or quilted with actual burl "clusters" but sold as "burl".
For drawer fronts, I suggest smaller burl flitches, bookmatched in the center for better or more distinctive walnut burl visual effect.
Chico...
This is nearly what I saw......
>I saw a TV (?) demonstration of this somewhere along the way. The burl was a big wart on the side of the log. They attached the log to the "lathe" and rotated it past the knife. Can not recall whether it made the full circuit/rotation or it just rocked far enough to cut the veneer off the burl. The explanation was that this made the burl slices very similar to each other and as large as possible.
Re: Think so.......
Thomas S Stockton
>I kinda agree with Chico. When I'm looking for veneers what matters to me most is how they look and is it the right look for the piece. It really doesn't matter to me what method they used to slice it. The thing about burls is that no two look the same this is especially true with walnut. Last time I got some walnut burl I looked at a lot of flitches that I thought were just plain ugly and uniteresting or would have taking a lot of time to patch the defects.
Bottom line take your time and find the right wood for your project, walnut burl is pretty plentiful and you should have lots of choices. One last thing is the stuff is not cheap but it really doesn't take much sqaure footage to build a piece so don't try to save money by skimmping on the burl.
The burl in the picture below came from another source I've used www.theveneerstore.com
lots of pictures of the actual flitches on their site.
Tom
How......
Bill Tindall, E.TN
>How could one possibly rotary cut a burl? To do a rotary cut one needs the cant to be a cylinder, not the optimum shape for a burl.
There is a process that is used on small logs that swings the cant through a 90 or 180 degree arc, not 360. The result produces flitches that look almost like flat sliced veneer and not at all like rotary cut with its repeating pattern. I could imagine a burl mounted on its flat side and being sliced this way but the result is going to work and look, just like flat sliced veneer and not at all like rotary cut.
I don't know about Bubinga, but I have seen flitches (which only result from slicing, rotary produces sheets) of birds eye maple at the plywood plant.
Re: How......
Thomas S Stockton
>Good question Bill. All I know is that when you go to Certainlywood's web site and other sites in their descriptions of some of their burls, kewazinga and birdeye they describe it as rotary cut and others they call flat cut. No idea what technique they use, like is said before what interest me most is how it looks.
Tom
makes sense
Bill Tindall, E.TN
>That is the way small logs are done now days. The result looks very close to flat sliced but one gets wider flitches from the "tiny" logs they veneer now days. It would make sense to do a burl this way to get wider pieces and better utilize the burl. On a burl I doubt one could tell this result from flat slicing.
I have never seen a mill slice a burl, but obviously there must be one somewhere (I suppose China!). . Strange is it might be the burls and crotches are sawed off veneer logs sold from these parts. I got a magnificent cherry crotch 32" across two years ago that was sawed off a cherry veneer log and discarded to the trash pile.
Re: makes sense
Thomas S Stockton
>I think a lot of veneer is still produced here and in europe but am not sure probably depends on species. dried flitch's are way cheaper to ship than wet logs.
Tom
extreme veneering, Chine style
Bill Tindall, E.TN
>I was at a log yard a while ago and struck up a conversation with their marketing person. He had recently been to China and saw them slicing veneer from maple lumber! He said it was so thin as to be translucent.
Re: extreme veneering, Chine style
>My friend is a cabinet maker. Some of the plywood he bought recently had veneer so thin you could sand through it with 120 grit sand paper in three or four strokes. I could not see the edge of the veneer even in bright sunlight.
