HF 20" Disc Sander
Woodie49
>Any one have any experience with the Harbor freight 20" Disc Sander?
Thanks
HF 20" Disc Sander
Woodie49
Thanks
No but...
Ellis Walentine, Host
>... here is a list of reasonable assumptions about it... First, it is made in China, possibly with supervision and/or assembly in Taiwan. Second, a disk sander is a relatively simple piece of gear, so it doesn't rely too much on critical machining or tight manufacturing tolerances to function well. The important things are the flatness of the disk, the quality of the bearings, and the quality of the motor. The motor and bearings are going to be standard Chinese issue, which isn't necessarily bad, but you're not getting name brands like Baldor and Fafnir, so don't expect a lifetime of perfect performance from them. That leaves the flatness of the disk as your main shopping criterion. It should be easy enough to manually spin the disk and check it for balance and runout without even starting the motor, but it would be better to actually try the machine you're buying, as there is considerable variability to be expected in HF equipment in my experience.
Fit and finish are always less than wonderful in this type of equipment, and you may want to file off some rough edges here and there to make the machine more user friendly. If there is a balance issue, you probably can fix it yourself with some judicious drilling on the back of the disk, but I wouldn't suggest that unless you have an experienced person guiding you. We always relied on a guy named "Frenchie," who could balance or tune any machine to work better than new. There aren't many Frenchies left, sad to say.
Re: HF 20" Disc Sander
Jay St. Peter - Southern, MD
>A few years ago I was shopping for diac sanders and the HF was on the top of my list. I read several reviews on various forums and all were positive. I wound up with a 12" Jet as I had a need and not enough cash, but I'm happy with it. IIRC, it was made in the same factory with the Jet/PM versions. Probably has a cheaper motor & switch, but I recall the disc, table and trunion were not downgraded. There may also have been something bad about the miter gauge (or maybe it didn't come with one). But, that's easily fixed for much less than the cost differential to the next cheapest 20"er around.
Jay
