Question about finishing Oak
Bernard
>I am looking for feedback/opinions/advice on a project I am working on in the evenings. It is a large bookcase unit with cabinets (total of almost 13' wide and 10' high at the peak. If anybody wishes, I can post a pic of the rough sketch.
Anyway, this is all being done with oak plywood and oak boards (my daughter's choice- it is going in her house) with a medium brown Sherwin Williams stain (forgot the name, and I am at work). The big question is the finish.
The criteria are the following:
a) I am not a professional, even though I try to pour my heart and soul in my work, so I am looking at something relatively easy to apply, even though I will be meticulous and patient in whatever I decide to do.
b) I do not have a sprayer, and therefore would prefer to brush or rub a finish rather that experiment with spraying.
c) I am working in an attached garage, in which I am both building the cases and will finish (therefore I will try to finish all the sanding and then vacuum everything up and then let it all settle before finishing to minimize dust.
d) The bookshelf unit will occupy a wall facing south in a Florida house with plenty of windows, so it will be getting a decent amount of sunshine (although muted in the summertime when the sun it hottest but more directly overhead).
e) All the wood will be oak boards or oak face plywood.
f) Water spillage will not be concern, unless the dogs and cat decide to use my work as a litter box.
I originally had somebody put a bug in my ear about mixing BLO with turp and varnish and rubbing it in, that it provided few problems with oak, but I realize that the finish will not be very tough.
Somebody else encouraged me to use a brushing lacquer such as Deft, but I am concerned with fumes, and that a brushing lacquer will not dry as fast as a spraying one, therefore negating the advantage of fast drying to avoid dust nibs.
Right now, I am leaning towards using a good varnish (any recommendations on brands???), thinning the first coat for better absorption, and then applying two more coats on top of that.
Any thoughts about this, or any advice about anything I should absolutely do? I am still weeks away before finishing, but I have gone dizzy over trying to choose a finish, and frankly I love the construction part, but the finishing part freaks me out a bit.
Any and all comments are appreciated. Thanks!!!!
