Pecan wood
Pecan wood
Pecan wood
Fred Davis
>Saturday ,I went to Leon Nelson's Custom Hardwoods sawmill to pick up some Kentucky coffee Bean Lumber for a Chest of Drawers project , that I wanted to do in a wood I haven't tried.
I had glanced at this stack the week before and then Saturday I saw a stack of really nice flat, no end splits , cups or wows light brown lumber. Boards ran to 14 " wide and eight plus feet long.
So I said , what's this Leon and he said he got a semi load of Pecan from Oklahoma , ran the down grade into flooring and the stack I was looking at was what was left, never been picked over , perfect.
So here's the question, never having used Pecan and I favor clear Lacquer finish over stain as a rule , what do any of you who have used this pretty wood use?
Since the color is already there and the sapwood is creamy white , I am torn between all tan or a mix of Heart and sapwood.
The only thing I didn't catch , because it was skipped planed and I was in a hurry was the sticker stain on about half of the boards.
When I planed it , the stain became obvious.
That may go back to him next trip.
FredD
Re: Pecan wood
Pecan = Hickory
Bill Tindall, E.TN
>Once it goes through the saw a pecan tree and hickory become equal. It is an inexpensive wood. It was popular in furniture a while ago and continues to be in flooring and kitchen cabinets. It is about the only wood that I don't stain. However, use a finish that doesn't yellow if you want the white to stay that way. Panels with an edge of sap wood and the center heart wood can be very attractive with this wood. The reds will fade with time. You will discover that the planer groans when planning it. It is very hard!
Post a picture of what coffee wood looks like. There are the few rare trees around here but I have never seen the lumber.
I suspect the sawmill man was well aware of the sticker stain. These sorts of defects are apparent to persons that handle a lot of lumber.
Re: Pecan wood
Love it
Chris Knob
>It was a very popular kitchen cabinet wood for custom jobs about 10 years ago but the appeal has waned somewhat. Incredibly heavy and hard...and inexpensive. Great workbench material. Only drawback is that it's a big mover with humidity changes.
Re: Pecan wood
Re: Love it
Ken Oakley-Sunny St. Cloud, Fla.
>And smells great when machined
Re: Pecan wood
Re: Pecan wood
>We had a custom cabinet maker outfit our kitchen with hickory, carefully picking pieces containing both light and darker wood. These have a light stain (fruitwood or somthing like that) and are finished with lacquer. We are will pleased with the result.
Re: Pecan wood
Hickory photos
Grant in Iowa
>Fred,
I completed a table top made of Shagbark Hickory about 3 years ago or so. I have attached photos of it below and in the next message. The first photo shows the table top newly completed, and the next photo shows the table as it looks now. It is finished with no stain and General Finishes Seal-A-Cell and Top Cote, using a wipe on technique with light sanding between coats. A final wetsanding and buffing was done afterwards.
The hickory works fine with well tuned and sharp tools. A bit of burning was experienced with the router, as well as a tendency to splinter if heavy cuts are attempted.
I am not sure of the precise similarities between Shagbark Hickory and Pecan, but also consider the wood expansion characteristics of hickory when you construct your project. I believe it moves more than more common woods.
I would not hesitate to build with Hickory again, as it has a pleasant smell when machining, holds up to abuse well, and finishes nicely. I would also add that while the late and heartwood will eventually blend, it is still a pretty wood to look at.
Regards,
Grant in Iowa
Re: Pecan wood
Picture of the table after 3 years:
Grant in Iowa
>Here is a close-up of the top today
Re: Pecan wood
Re: Love it
Lee Schierer - McKean, PA
>Our entire bedroom suite is made from hickory. It is a very hard wood and will sand to a very smooth finish, but it takes a lot of time. The wood smells nice as you cut it, so much that you almost want to misalign your saw so it burns when you cut it.
You can stain it, but it won't get very dark because the grain is not porous. Pay close attentention to grain direction when planing or jointing or you will get tearout. It will give your planer and saw a true workout.
Hickory was tradionally used for hammer and garden tool handles. It became popular a few years ago for the rustic kitchen look. Personally I don't care for the sapwood and heartwood mixed look.
You'll want to cut it with carbide tools and be sure to drill pilot holes slightly longer than the screw for any screws you put in it. You'll also want to lube the screw threads with beeswax before attempting to screw them in otherwise you will probably break the screw.
Lee
Re: Pecan wood
Re: Hickory photos
>Very nice; I like the edge treatment.
Clint
Re: Pecan wood
Grant, please eamil me
Bill Tindall, E.TN
>I have some questions on the table. ignore spam message you will get.
Re: Pecan wood
Re: Picture of the table after 3 years:
Fred Davis
>Grant,
your second pic is pretty much a dead ringer for the freshly planed Pecan I have now.
I hadn't heard of Hickory as being the same , I have a few sets of cabinets done for clients who like the "rustic look of Hickory" , which at least in the wood furnished by J.E. Higgins hardwood lumber in Union City , Ca. was full of knots, this Pecan could grade to FAS one face for a lot of it.
Thanks to all for the reponses.
FredD
Re: Pecan wood
Re: Pecan = Hickory
Fred Davis
>Bill ,
I didn't get the Coffee Bean Tree lumber, but if you picture Ash with a reddish tint you got it.
Your being to generous referring to Leon Nelson as a "sawmill man"
He has a new facility with a new WoodMizer band mill in it, that's it.
Coupled with a new Dry Kiln , it's a place you would love to own.
No log sealing or lumber end sealing , end splits in nearly every board he personally processes's , no grading , all same pile, no rift or quarter sawing, has difficulty doing board footage, but he is a nice guy , does try when you ask , but given his age and rancher back ground , there is a slim to none chance of retraining him.
Since he got the Pecan from a Oklahoma source , and run most of it into flooring , sticker stain would never enter his mind as a defect.
His facility is neat , lumber well stacked and stickered and his warehouse /shop is slab heated , so the plus's out weigh the minus's.
FredD
Re: Pecan wood
Dale Lenz
Re: For the record
Dale Lenz
>Respectfully, if you follow NHLA rules(at least in years past) the pecan and hickories are somewhat separated into Hickory-Pecan and True Hickory. With out looking it up, some of the hickories are grouped with pecan and some hickories are grouped with only hickories. As Bill stated most sawmills lump the two together, hickories and pecans. Most folks could not tell the difference between pecan-hickory and true hickory. I can only tell the difference with a 10x hand lens and razor blade, wood properties maybe be somewhat different(?).
Re: Pecan wood
Re: Love it - O.T,
victor parisian
>It is the best wood to slow cook a brisket on. No bitterness as with oak and mesquite. The odor should drive your neighbors insane.
Victor - in Houston
