THE WOODRAT IS BACK!
3 cabinet questions
3 cabinet questions
3 cabinet questions
Terry Alexander
>Norm did a series on cabinets 101.
In this series he used pre-finished white maple plywood.
Q#1: Does anybody know a source for this in Texas? Preferably West Texas?
In the same seris Norm mounted drawers with "standard" slides mounted on the sides of the drawers and also some mounted underneath the drawers. Seems to me that if you put slides under a drawer and it was the bottom draw that it would be a total pain to install and rem
ove.
Q#2: Do you need "special" slides if mounted on the bottom or are they all the same?
Q#3: Do any of you have any pros and/or cons regarding mounting slides on the sides or on the bottom?
As always....TIA for your valued advice.
Terry Alexander in West Texas
Re: 3 cabinet questions
Rod Peterson -- Ormond Beach
Can't help you on this one.
> In the same seris Norm mounted drawers with "standard" slides mounted on the sides of the drawers and also some mounted underneath the drawers. Seems to me that if you put slides under a drawer and it was the bottom draw that it would be a total pain to install and remove.
The bottom mount slides are so the slides are "hidden," and they're not the same as the side mount slides. Unless your drawer is sliding along on the floor, they are no more of a pain to remove than any other drawer. You pull the drawer out, reach your fingers underneath on each side and move the locking lever to unlock. Then just pull the drawer out and off.
Every drawer I've ever built I've used the side mount slides. They're less expensive, less complicated, and pretty much idiot proof. The new kitchen we put in three years ago (I didn't build them) has under drawer slides and I think I've yet to feel the need to remove a drawer. From a use and functionality point of view, there's not much difference. You do get nearly 1" more drawer width per unit with hidden slides vs. the side mount.
Aesthetically, if you're offended by seeing the slides when they're side mounted, then the hidden ones are obviously better for you.
Conceptually, just thinking of the loads and the construction, I would expect the side mount slides would handle drawer weights better because their orientation is vertical. The hidden slides are oriented horizontal, and while they're still rated at 100 lbs (in many applications), it just seems a spongier feel to me in my kitchen.
I don't know if Blum or Accuride (or any of the others) have the "self/soft close" in the side mounts as well as the hidden, but if they don't, that may be a selling point, as well.
Finally, the last time I priced slides (a few years now), there was something of a premium on the hidden slides versus the side mount.
So, basically, I've told you nothing. Worth everything you paid for it!
Rod
Fred Davis
>Terry , having built kitchen cabinets for years for a living , I gradually sorted out the pros and cons of slides and over the years metal slides have improved greatly.
That being said , I personally prefer side mount to bottom mount for a couple of reasons.
The bottom mounted slides typically seen on model home cabinets and production shop cabinets are inexpensive relatively speaking and are basically junk.
The other type of bottom mount which are 100 % invisible run to about 78.00 a pair for a medium grade slide rated at 100 Lb. fully extended.
This high price killed off the notion of doing them on a high end chest of drawers for a friend of mine's wife.
I like Accuride because they have been in business a long time and have kept apace with improvements.
I use their side mounts #3820 , buy them a hundred at a time in boxes of ten for the best price break.
They have self closing , soft closing and lately the rage is drawers that will spring open at a touch relieving you of the need for pulls , if you like a clean drawer front.
Beyond that the most critical part of installing side mount drawer sides regardless of the brand is the 1/2" clearance at each side of the drawer box , that cannot vary more then a 1/32" without either having a tight fit that won't open easily or so loose the drawer falls out of the slide part mounted in the cabinet.
if you watched Norm and paid attention , you will discover that his methods of work are straight forward, well thought out and result in nice appearing projects.
For prefinished Plywood , they should be many outlets in Texas that cater to the Cabinet trade, not big box stores , cabinet shops.
This probably didn't answer all of your concerns the first time , but email me anytime.
FredD
