ADVERTISE HERE - FREE TRIAL
Way Off Topic - Kitchen Sink
Dean B
>Sorry for the off topic question, but I can't get an answer anywhere else I've tried. I installed a new SS sink (over countertop). The rim to countertop fit is fine. It recesses to the part I will call the deck (where the faucet mounts). This area slopes slightly towards the sink basins (I assume for water runoff). When I intalled a tall swan neck type faucet to this sloped surface it makes the faucet tilt noticably forward. There is no way to adjust the faucet mount that I can see. Is this correct and normal, or should the deck area be dead level? I hope I have describe this well enough. Thanks.
Re: Way Off Topic - Kitchen Sink
Mounting Hardware
>Recheck your hardware bag/box looking for a washer that is thicker on one edge than its opposite. If it's not there, call your plumbing supply house with the name and model of the faucet and explain your problem again. They should have a wedge-shaped washer that will correct the misalignment.
Ditto ! . . .
steve mackay
>Installing my first "expensive" set-up did the same thing but with no one to ask. Sat and gave it the evil eye for an hour before I noticed the "bevel" of the "washer" / seal. Turned it around and all was well. Still not sure it was in the directions. I was so relived I just gave an "Amen" and packed up the tools ! Just in case . . . I never understood about plumber's putty either and didn't use it 'till this set-up. And, Yes Virginia, it really does serve a porpous. Live and learn I guess.
Warning
>Never (ever) use plumber's putty on a granite or other stone countertop install. The oil in the putty will leach into and stain the stone such that a dark shadow will appear, developing over a rather short period of time. While a stone poultce may be used to draw some out, you'll never get it all. My fabricator insists that 100% pure silicone (preferable clear unpigmented) should be used instead.
Same goes for cultured marble sinks, DAMHIKT
Didn't know that one. Thanks !
steve mackay
