Re: Band Saw Tire Changing
Paul Murphy
>I had exactly the same experience. There are 2 problems with the Carter tires on the Delta 14" bandsaw:
First, the tires are at least 1/32" thinner than the tires that came with my bandsaw. C=3.14D so there is at least .2" right there.
Second, the tire is not as wide as stock, and will not fill the groove of the wheel. This may lead to tire shift, or a lack of blade support if the tire is fully biased to one side of the groove.
I called and emailed my supplier and Carter over a year ago concerning this issue, but neither company seemed concerned. I did return the tires for a refund, and found full width and thickness urethane tires elsewhere. The full thickness and width tires worked beautifully, and their first test was a bent lamination resaw which I couldn't have been happier with. IIRC I found them at Hartville Tool.
Your other option is to slip a spacer under the end of the tension adjuster. I didn't like having to modify my saw to make a purchased part work, and didn't want the spacer to possibly slip, so I didn't do that.
