THE WOODRAT IS BACK!
sharpening carbide saw blade teeth?
Joseph Mulherin, Sr
>I have a 60 tooth 10" blade that is dull. Can I sharpen it here at home with my air-drive handheld grinder. Blade is about 3" dia. high-speed. Do you just sharpen the face of the tooth?
Am building Curtis Gray's TV console entertainment center, which he posted a few days ago...but mine is out of Birch plywood, stained golden oak and is going to be polyed.
Re: sharpening carbide saw blade teeth?
Fred Davis
>Joseph,
that is a job for a sharpening sevice for a host of reasons , it wouldn't even be close , but it could be ruined.
For instance do you have a diamond wheel, a way to measure side grind, if you need it , can you tell if it needs it.
and on and on.
FredD
>I have "touched" up or honed carbide router bits. I would NOT want to attempt to do a carbide saw blade. IMO, it would be very difficult to be consistent. At $0.25 a tooth, I'd pay the money and let a pro do it.
Joseph Mulherin, Sr
>OK, guys, I agree that they blades are going to a sharpening service. I went over to the local Home Depot and found a 60 tooth Oldham 10" blade for only $19.93. Brought it home, installed it on my Shopsmith and cut my trim birch boards for my entertainment center. Cut fine and I am happy. Installed the trim nailed to frame and will caulk any flaws in joints, sand and then stain probably on Wednesday.
Am taking pictures as I go along and will post them later when finished.
