Tambour Mantle Clock Curve
Don J
>I've been planning to build a Tambour clock for years but havent decided the best way to build and cut the Bell_Shape top curve. (See Example)
One thought was to glue the figured cherry 'boards together and cut the bell-curve exposing edge grain.
A second idea was to stack boards and cut the curve exposing mostly face grain, but that would highlight glue joints on the ends and show end grain.
I'm an amateur with common garage shop tools: Tablesaw, Drill press , router table , scroll saw and all the power and handtools. I have access to a band saw.
Any recommendations? Any practical advice is greatly appreciated
Re: Tambour Mantle Clock Curve
Don J
>I also should add, I was trying to avoid a final thin laminate on the curve as I wanted to add some 'moulding-shaped overhand and two shaped breaks in the curve sides.
>What's wrong with veneer? Build up the inner portion via brickwork or whatever, shaping it and putting a veneer over it. I don't really have an idea of the dimensions. How thick, wide and tall do you want it?
del schisler
>i been in clock's for yrs Some are real thin and probly steem formed and than veneer Than i have seen some that the we will say a flat board than saw relief all along the borad so you can bend it of course the bigger relief's the smaller the clock bend will be So this would be a test to see what will work Most i belive are made from poplar wood most likey 3/8" thick so the saw lines on the board has to be just right If you are going that route Mite be fun making one The base wont be a big job for this the face and back will make the case stiffen up Probly made out of 3/8?? You can of course cut it out of 1" board the shape you want It would take 5 board's glue them togather Only 1 cut out for the bezel Cut The case frount to back is most likey 5" thick Lots of way's to make this clock I have made clock and sold thro antique trader yrs ago
John McGaw
>I've had a few similar curved-top clocks over the years and every one of them was done in some form of veneer. The one that I still have is in what appears to be mahogany veneer with a bookmatched front and has a slightly more complex curve on top and also has a curve to the front. It has some rather fancy moulding but that is an applique in a typical 1920s fashion. If I was building a clock similar to what you show I would most likely make the top using a laminated veneer layup.
Use a pattern on your router table *LINK*
Bricofleur
>Don,
As shown on the picture, make yourself a pattern out of 1/4" MDF or hardboard (with perfectly sanded edges) that you will use on your router table with a pattern bit or a guide bushing (depending on your router table). Make it the shape of your clock. Add toggle clamps to keep it from moving/shifting and guide fences. Since you will be routing down the grain and up the grain, I suggest to use the jig half way from the top so you would rout with the grain making one side of the clock and then flip the workpiece and rout the other side, still going down with the grain.
Important: Use a safety pin or provide your pattern with a flat spot from where you would start routing. Don't feed the stock/pattern directly on the spinning bit. The bit may catch it and throw it away.
PS: The pattern on this picture was to replicate 6 identical feet for a bed.
You can also check the appropriate page of my website.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
Router Table Pattern Fixture
Don J
>Of course, you're right; but I stubbornly was trying to to figure a way to make it "solid cherry" without the veneer build up.
Don J
>del schisler:
I hadn't thought of relief curfs to be able to bend the wood.
You're right , it would have to be tested and done juuuust right.
With the curfs and maybe a little 'steam' to avoid cracking it could work out nicely. I'll think about this method.
Thanks
Re: Use a pattern on your router table
Don J
>Serge,
That's a good idea for getting an accurate and consistent curve. The only problem I can see is the length of the bit may not be long enough even flipping the top and routing from both sides to the center. It sure a method I'll consider!
Thanks,
Don
Don J
>One other idea may or may not be practical:
Would laying out the curved pattern; and then cutting the cherry in grain matched "straight" (maybe 1" thick) glued up segments to cover the pattern; and finally cutting the pattern curve?
This should leave face grain throughout the curve. One drawback would be the exposed butt joints, but at least two could be hidden by adding moulding trim.
Don J
>Serge,
Would laying out the curved pattern using your jig idea; and then cutting the cherry in grain matched "straight" (maybe 1" thick) butt- joined segments to cover the pattern; and finally cutting the pattern curve using the router work?.
Two of the butt joints could be hidden by adding a trim molding.
The curved surface would be all continuous face grain.
Hmmm, I may have to run a test to try this idea out.
What do you think?
Bricofleur
>Don,
I don't know how thick if your clock, but it can be done on the router table with a pattern jig and a long straight bit. As example, my longer 1/2" straight bit is 2-1/2" long, which should work if your pattern in 1/4" thick and your clock 2-1/4" thick. I don't know if pattern router bit with bottom mounted bearing are available that long, but using a guide bushing let you use any straight bit.
I would suggest you roughly cut the bell shape on your band saw and then make a clean cut on the router table as mentionned.
Clear enough?
Best,
Serge
