OT - Cement Board vs. Hardiboard
Steve Silca
>This is a multi-pronged inquiry - I would just like to hear yor preferences and recommendations. I have done a fair amount of tile work and always worked with 1/2" cement board, taped the seams, used screws to attach it. I have several more tile projects coming up and wanted to consider alternatives.
1. If you were doing a tile surround for a tub/shower, would you use cement board or hardiboard? If you use hardiboard, how do you tape the seams?
2. If you were doing a floor, would you use hardiboard or cement board? What thickness
3. I am going to wrap my exterior wooden steps with tile. So, I will be applying tile to the front of the treads, the top of the treads, and the risers. Right now they are sturdy wooden steps. I am thinking of applying the 1/4" hardiboard as a substrate. What do you think?
4. When can you use 1/4" or 3/8" cement board?
5. Finally, I have always used mortar and screws to attach backer board, but have seen videos of people doing it with a roofing nailer. Does a roofing nailer (1 1/4" nails) and mortrar suffice for backer board installation?
Thanks for any input you can offer!
