O T painting a link fence
paul waddle
>What is the best applicator for painting a chain link fence? Will a roller work,a wagoner sprayer. or a labor intensive brush. The paint will be aluminum-probably a high viscosity. Thks,pw.
Re: O T painting a link fence
>I've seen what looked like pro's painting them with a long nap roller. Take your time to find the right "speed" to give the paint time to flow around the laps.
It goes pretty fast, After all, you don't have to paint the holes.
Bill Tindall, E.TN
>Roller with a very long nap roller. I have done miles. The long nap wraps the wires and it goes faster than a wall. You and the environment will be shiny aluminum colored after the job.
Double your fun
Lee Schierer - McKean, PA
>For faster results and even more fun, get two workers working opposite sides of the fence with long knap rollers at the same time. ;)
Lee
Re: Double your fun
paul waddle
>Long nap roller it is... thks,pw
Re: Double your fun
Fred Davis
>Paul,
You did say Aluminum fence , so I would trot down to the nearest paint store that has a knowledgeable manager( yeah I know , nearly impossible to find) and ask him or her , to reccomend from the Manufacturers data sheet, a paint that is designed to stick to aluminum.
Because aluminum is a self -protective metal , most paints will fall right off, after you went to all of that work.
FredD
aluminum paint
>Paul didn't say, but most chain link fences are steel coated with zinc; some are coated with plastic which is difficult to paint successfully.
Pressure washing may be needed. Any spots with rust should be treated first with a wire brush - I'd treat rusted areas with a conversion coat or primer before painting.
Aluminum paint sticks to almost everything.
