Has anyone made a futon using the Rockler plans?
Bruce, a MN Galoot
>I'm in the early stages of planning a futon frame couch and the Rockler plans seem to get generally favorable reviews. However, I'm not convinced about the joinery and so am thinking about beefing up that part of the plans. Specifically, everything seems to be bolted together, which doesn't seem like very fine joinery to me. I'm planning to add M&T joints on the corners of the seat and backrest frames, stub tenons where the front and back rails are joined to the end frames, etc.
So, if you have any experience with this or any other futon couch plans, please let me know.
Thanks
Bruce, in MN where spring just won't spring...
Re: Has anyone made a futon using the Rockler plans?
Ed in Lawrence, KS
>Bruce, I made a futon from Woodsmith plans (vol. 26, no. 152) and was very pleased with the result. I think I got all of the hardware from Rockler so it might be very similar to what you're building. Is it fine A&C furniture? No. But the ends do use M&T construction and the rest is very functional and will serve its prupoose very well. I'm not concerned about it holding up over the years. YMMV
I KNEW that Woodsmith had a plan
Bruce, a MN Galoot
>and just couldn't find it. Thanks for the reference and the vote of confidence in it. I even have that mag.
Bruce
JimG------WebKitFormBoundaryAA2hAApkAA+UAAXL
>I made it. The compression joints work fine. We've had ours for 5
years? Teenagers and all, it still looks and works great.
