OT:Source for HP 5000N WinXP 64bit drivers?
Dominic in Bucks County PA
>Hi gang,
Anyone know of a source for Windows XP (32 & 64bit) drivers for the Hewlett Packard 5000N Laserjet? I'm talking the Universal Print Drivers here.
Before you ask:
  1. Yes, I've tried HP's website. Several DOZEN times!! There is something wrong with their web site.
  2. And YES, I've tried it on another computer (at another location) and gotten the same "550 Permission Denied" error message.
  3. And YES!!! I've tried Googling (or Yahoo-ing) the phrase "HP 5000N Windows Xp Drivers" with little or no success
My brother gave me this printer and I have in turn brought it into work to use. Having the capacity to print 11x17 is a must when making AutoCad drawings. At one time my brother had the original CD but has since mislplaced it. So I'm SOL without drivers.
And help here?
later,
Dominic
Re: OT:Source for HP 5000N WinXP 64bit drivers?
Re: OT:Source for HP 5000N WinXP 64bit drivers? *LINK*
John McGaw
>I don't know what happened when you searched HP's site but I had no trouble finding what they claim are the proper drivers for XP 32 and 64-bit for that printer series. Try the included link and see what happens.
HP Driver Page Link
>"Yes, I've tried HP's website. Several DOZEN times!! There is something wrong with their web site. And YES, I've tried it on another computer (at another location) and gotten the same "550 Permission Denied" error message"
Original post states the reason I didn't get it from HP web site. I geta server error every time I do.
Dan Donaldson
>Goes through fine for me. According to the website, the driver for that model should be included in the windows xp 64 bit install, and you do not need a separate driver. Here are the instructions as printed on the HP site :
HP LaserJet Printers - Installing the Printer with the Driver Included in Microsoft Windows XP Professional x64 and Windows 2003 Server x64 Edition
Introduction
Step one: Check to see if the printer driver is already installed
Step two: Connect the cables
Step three: Manually install the printer driver
Introduction
Not all products have Windows XP Professional x64 or Windows 2003 x64 Server drivers available for download at this time. The drivers for your HP printer are included in Windows XP Professional x64 Edition or Window 2003 x64 Server Edition.
NOTE: Click here to go to the HP download site: Ckick here to go to the HP download site at URL: http://welcome.hp.com/country/us/en/support.html?pageDisplay=drivers
The following instructions are for installing the basic driver that is preloaded on Windows XP Professional x64 or Windows 2003 x64 Server. This document describes how to load the appropriate printer driver that is pre-installed in your operating system. The preinstalled Windows XP Professional x64 Edition or Windows 2003 x64 Server driver supports basic printing features.
This document only addresses the Windows XP Professional x64 Edition and Windows 2003 x64 Server operating system. This document does not address Windows XP Home, XP Professional, and/or Media Center Edition.
To find out if printer is already installed, do the following:
1. Click Start , and then Control Panel .
2. Click Printers and Other Hardware , and then click Printers and Faxes .
3. Check to see if the name of the printer shows next to a printer icon.
* If the printer is there the best printer driver is already installed. Proceed to Step four: Set the HP printer driver as the default driver .
* If the printer is not there, proceed to "Step two: Connect the cables .
With the computer and printer on, connect the USB or parallel cable to the printer and the computer. One of two things could happen:
* The driver automatically installs when the printer is connected to the computer. Several small dialogue boxes will appear showing the progress of the driver installation. When the installation is finished, a message displays stating that the printer is installed and ready to use. The best printer driver available for the printer is installed. Proceed to "Step four: Set the HP printer driver as the default driver .
* If the Found New Hardware Wizard displays, click Cancel and proceed to Step three: Manually install the printer driver .
1. Click Start , then Control Panel .
2. Click Printers and Other Hardware , and then Printers and Faxes .
3. In Printer Tasks, click Add a printer .
4. Click Next .
5. Select Local , then remove the check mark from Automatically detect and install my Plug and Play printer .
6. Click Next .
7. Select Port .
* Parallel connection is usually LPT1
* USB connection is usually USB001
8. Click Next .
9. Select HP from the Manufacturer list.
10. Select the printer model from the printer list, and then click Next .
NOTE: If prompted for a Windows disk, do not use the disk that came with the printer. Use the Windows XP disk, Windows 2003 Server disk, or the recovery disk that came with the computer.
11. Select Yes if this printer is the default printer, or select No if it is not.
12. Click Next to continue.
13. Select No to skip the test page, and then click Next .
14. Click Finish to complete the installation.
15. If prompted for a Windows disk, insert the appropriate Windows or PC Recovery disk (not the disk that came with the printer) and follow the instructions on the screen. Once the driver has been installed, it will be listed in the Printers window (Start , then Printers and Faxes ).
Once the new HP driver is installed, set it as the default printer.
3. Right-click the HP printer driver, then select Set as Default Printer .
Corporate Firewall was the culprit
Dominic in Buck's County PA
>It seems that while the PC's firewall was fine, the corporate firewall was not allowing me to download from HP's FTP site. Go figure.
And as far as the drivers being included with WinXP, I haven't found that to be the case. It's probably because I inherited this PC from another person and WinXP came from Dell installed already.
Anyway, from my home PC I've downloaded all the applicable drivers and have copied them to a USB for installation at work.
Little info about UPD
>Couple of things about HP's UPD.....
Designed for Vista? Vista came out and there were too many old HP LaserJets to rewrite drivers for each of them (HP LaserJets do last forever) so they came up with the Universal Printer Driver idea.
Works on XP/2003? Not with problems.
Going forward? Looks like they see a huge value in providing one Universal Printer Driver for all new model in the future, so that the need to build, maintain, find, install drivers for each model is gone.
Since you are running XP and not Vista or 7, and since you're talking about an older LaserJet and not one of the new ones, I'd suggest trying the old specific driver first before the UPD. Also, there are several versions of the UPD, some not available to the public yet.
This is just my honest opinion. I've been installing HP LaserJet's for 20 years and have always worked closely with HP system engineers, especially recently with the UPD.
Hppe that helps.
Happy Woodworking!
Laserjets Forever?
Jerry Nicholson
>Do Laserjets really last forever? The oldest one I have (Laserjet IIIp) is only 18 years old so I wasn't sure if they would last forever or not but it still works great although a lot slower than my Laserjet 1320.
Jerry
