Wood rack design comments
David Hammelef
>Ok, thanks for all the input earlier. Took some of those designs, with a few others I found and have started on a rack...
2x4 arms, the supports will be 2x4 sandwiched between 1/2" ply. (cut about 1/8" narrow than the 2x4 so about 3 3/8") the ply will stop about 5" from the bottom, and extend 5" above to grab the floor truss. Center section 2x4 are about 10" long with a 2 deg angle in them.
All the wood is cut, the question is how to assemble. Original thought put down ply, glue 2x4 put down and screw. But I think I want the screws coming in from the ply side. Also should I glue and screw in the arms, or leave them free floating so I can remove if I need more height than 10".
Im tired, and maybe making to big a deal out of this. Maybe I just lay the 2x4 down (including arms to keep spacing correct) and glue and screw just the leg parts. Can use clamps to keep the 2x4s straight I think. Any thoughts????
Something like this (See pic) but mine will go to the floor, and is using thicker ply.
