question...caulking with silicone
Bill Tindall, E.TN
>I have the table made that the marble tiles drop in. I have left a 1/8" gap to be filled with caulk, or tile grout or what ever.
I watched the Corian installers install a counter some time ago and they had a trick for filling a crack with silicone that I failed to write down. In any case instead of the stuff all lumpy and smeared about like I have accomplished in the past their "coves" of silicone were smooth and uniform and it wasn't smeared about. As I recall, the application involved Windex which kept the stuff at bay and enabled them to smooth it after laying down the bead. Sadly I didn't write down the procedure and now I have forgotten details. Did they spray before applying the silicone or after?
So, what is the best way to fill a crack with silicone and leave a nice smooth "coved"/(slight hollow) surface and not have it smeared on the adjacent surfaces?
Re: question...caulking with silicone
Fred Davis
>The first trick is to forget Silicone which is a bitch to clean up and use Polyseamseal whichs cleans up easily with water.
For coving I always used tip of my little finger or a damp cloth wrapped around it.
PolySeamSeal is a extremely strong adhesive caulk and you need to have the tile or the wood or the glass or whatever in the place you want it before the caulk sets up , which is pretty fast compared to most.
FredD
Ken Krawford
>I've also had great luck with PolySeamSeal.
I learned a long time ago that I'm a lousy caulker so I always mask anything that is more than an inch or two. The results looks great.
I second using a wet finger for a nice cove.
Justin Szeliga
>Blue tape on either side of the seam, use spit & cove it, pull the tape, wipe again w/a spit wet finger. If it was good enough for mom to use to clean my face as a kid, it's good enough for construction.
Peace
Justin
