inscribing a name------WebKitFormBoundaryT4M+HroUL
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>What's a good, simple, reasonably foolproof way to carve lettering in a board? (Maybe there isn't one.) I don't mean a burned signature, as many turners do on the bottom of their pieces. I mean something considerably larger-- perhaps each letter dime size -- and cursive. I don't have a pin router( and I certainly don't have one of those computer controlled $7500 machines.) So is there a relatively simple way? It's fancy wood, and I don't want to ruin it.
------WebKitFormBoundaryT4M+HroULw9AxQ5I
Re: inscribing a name------WebKitFormBoundaryT4M+HroUL
pecker
>You can print the lettering onto a white Avery label. Affix the label to your wood, then use a Dremel tool with a 1/16" or even a 1/32" engraving bit to trace over what you've printed.
If you don't have a Dremel, there are inexpensive engraving tools that use these same type bits.
