Cutting Thin Strips - (PICS)
David Yoho
>About a week ago someone posted a question about how to cut thin strips on the tablesaw. I posted a response describing the way I go about doing this and Ellis sent an email asking if I could write up the description again but add some photos to help clarify the process. So, here it is and I hope the images make it easier to understand.
Personally, I never like to run thin strips between the blade and fence because it's not as safe and the chance of the small strip getting mangled by the blade is always a concern. Whenever possible, I use the following method, which works better and is much safer. In the following example the pictures will show how I would cut a 1/8-inch by 1/8-inch square strip on my saw.
I start by replacing the standard insert with a zero clearance insert to prevent the small cuttoff from falling down into the saw. I usually set the blade height to about 3/16-inch, which does not change for both cuts.
In this example, I'm only making the cut on one edge (to make one strip) but I can cut four individual pieces by making the cuts on all four edges. If I need more than this, I simple joint the edges flat and follow the proceedure again to cut more thin strips. The first cut is on the face edge. Set the rip fence so the blade cuts a groove leaving 1/8-inch of wood on the edge.
With the first cut done, you're ready for the second cut.
For the second cut (that will release the small strip from the piece being cut), once again set the rip fence so the stock can be cut on its edge. After adjusting the fence, I like to use a featherboard to hold the stock against the fence during the cut. Then I just feed the stock through and watch the small strip fall off to the left of the blade.
The result is a thin strip of wood that can not get trapped between the fence and the blade during the cut. Should the small strip need further refinement after cutting, a little sanding with some paper wrapped around a block of wood does the trick.
David
Re: Cutting Thin Strips - (PICS)
A picture is worth....
Ellis Walentine, Host
>... a thousand words, David. Thanks for posting this follow-up.
