Try boiling it.
Charles R. Smith
>You could use the trick that many turners use... boil it. I have turned lots of bowls out of plum, apple, pear and other fruit woods that habitually split like crazy. However, after I started boiling them, my losses were a fraction of what they were -- from almost 100% cracks to less than 10%.
I would boil it for a couple of hours, preferrably outside, such as in a big pot on a side burner of a barbeque. Some folks might advise you to let it cool down with the water and then throw it in a paper bag to control the rate at which it loses moisture, but I generally don't bother. After two or three weeks, it should be dry. With my turnings, I used a small digital postal scale to see when the wood was dry (i.e., no longer lost moisture or weight), and unless the blank was really thick, it never took more than three weeks.
Charles (who loves the colours of plum)
