Dead bolt Idea needed
Sawman
>I am building an exterior door for a shed. It is 2x4 covered with 1/2" ply with 1x vertical cedar T&G.
I need some type of latch/dead bolt that will work from BOTH sides. The interior will be open to the cavity.
Ideas??
Re: Dead bolt Idea needed
Gene Gauss
>In the old days, they would often use a pivoted bar on the door that dropped into a pocket in the doorframe. A rope through a hole in the door above the bar would be pulled to lift the bar from the pocket and allow the door to be opened from outside, and it was operated directly from the inside. At bedtime, the rope would be pulled in to assure no one could enter. A way of telling people that they were welcome was to tell them that the "I'll leave the latchstring out". Something like that would probably work, and if you wanted to make sure that the door could always be opened from either side, you could attach a ring too large to pass through the hole. Some scrap wood, a hunk of rope, and a couple of screws and you'd have it.
Yes *LINK*
>On a gate in one corner of our spa area, I used one of those gate latches you can get in any hardware store (see link below), tied a piece of mason twine (nylon, yellow) to the handle through the conveniently provided loop, ran the twine through a hole, and tied it to a fence staple driven partway in.
This is infrequently used - you might need to step up a notch on the twine size for something used a lot, or line the hole with nylon tubing, or something, to avoid frequent breakage.
Like this
Pete in Holland, MI
>I made a drop latch for a shed door one time. Instead of the rope, I created a cam that was attached to a wood dowel, with a door knob on both sides of the door. Rotate the knob and it lifted the latch. A log thin piece of wood creates a spring to put downward force on the latch.
Sawman
>Thanks for the ideas!!
Bob Senich
>I made my shed door with a 2 x 4 frame, covered with 1/2" plywood on the indside and 3/4" cedar board on board fence style outside. I simply bored a clearance hole through the cedar and installed a "standard" doorknob and a deadbolt set. It's pretty common to find them for a 2 1/8" thick door and I chose a manufacturer that was comaptible with my home entry locksets..... The locksmith keyed them up the same as the house, no more looking for a shed key... I needed the security of a locked shed.
If you go this route, watch for backspacing on the lock set. You may need a 2 x 6 on the lockset side to keep from breaking out when you bore the holes.
Bob
