Weird wood floor question........
Jesper, Denmark
Jesper, Denmark
>I live in a house built around 1924. The original wood floors are still there in most places, particularly in two adjoining rooms - living room and the old dining room - which have a double door between them - always open.
The floor�is tongue and groove pine, which has been treated in many ways over the years, but at some time were sanded down to bare wood. They still are bare wood, which gets treated occasionally in the traditional way by scouring with a strong soap solution and then dried. The soap leaves a slightly "soapy" film, which prevents spills and dirt to get into the wood.
Here is the question:
The planks are all flat sawn and laid down with the pith side (center of the tree) up. Contraction from heating over the years and the frequent washing have caused them planks to shrink, so there are gaps of between 1/8 and 1/4 inch between the planks and the edges of the planks curl up. The gaps naturally collect whatever crap is around.
One thought is to ream out the gaps down to the tongue and fill something else in them. Sorta like caulk the deck on a boat. I suppose I could rout out each gap to make them all the same size or close to it.
Any suggestions to a suitable compound, technique or other ideas?
Re: Weird wood floor question........
Howard in Bethesda
>Jasper:
There was a compound that I used 5 years ago made for filling spaces between parquet squares, called something like corkit. It was made by a company called Corktech. I did a quick search and could not find the company.
It is coarsely ground cork in an elastomer base and worked great for me. You may be able to find a similar product used by parquet floor installation companies in Denmark
Howard
Howard in Bethesda
>Jasper:
I found a telephone number for the company, 860 851 9417 If you are interested in the product let me know and I will call them Monday to see if it available in Europe.
Howard
