Help w/highly eyed birdseye!
Barry Rubenstein
>I have an incredible board of highly eyed birdseye maple. Ran it thru the planer and got the start of lots of tearout of the eyes. Guess I should stop planing; should I belt sand it instead? Any other suggestions?
Re: Help w/highly eyed birdseye!
>If you had a Shelix or similar head, maybe you could run it through the planer. I would probably hand plane it with a nice steep angled plane and then possibly use a cabinet scraper. I don't like the thought of belt sanding it as it "muddies" the appearance of the birdseye in my opinion.
Alternatively, you could possibly belt sand it to smooth it and then use a cabinet scraper to "brighten" it up.
David Yoho
>Barry, I'd stop with the planer. Although you didn't say what type you're using, the only way I would try it with wood like you have and using a power planer would be if it were equipped with a Shelix or similar head. Barring that, it might be possible with one of the two-speed "lunch box" planners with a fresh sharp set of knives and dampening the top side with a sponge before feeding it through.
You could take the non-powered route and use the proper and sharp hand plane.
Finally, if you have access to a wide belt sander, that would work too but sanding tends to "dull" the figure. I'd follow it with a little work with a sharp cabinet scraper.
David
convert your lunchbox to a York pitch
Robin Corell in Atascadero, CA
>You can do it with your planer but you will need to modify the blades by adding a bevel to the back side to convert it to a york pitch. lot of stuff in that sentence so I'kk back up a bit. a yoork pitch is normaly found on a hand planer and is usualy aroung 55*. each power laner is different so you will need to try and figure out what angle the blade is at when it hits the wood. This can be different depending how much of a cut you are taking so use zero cut and figure the angle of the blade when it just touches the board. now make a large scale drawing of the blade and figure out what angle you need to put of the back of the blade to change the angle between the blade and the wood to 55*. I refer to the flat part of the blade as the back but on a power planer it is the part of the blade that stricks the wood first.
You will only need a relaticely small bevel and 1/32 is fine. you can make up a jig to hold the blade and use a hand held dimond stone and get very satisfactory results.
every thing has its down side and the down side to this modification is that you will not be able to take as heavy of a cut, but on birdseye you wont want to take a heavy cut anyway. An added bonus to this modification is that it is also good for very abrasive woods like teak. the reason for this is that the included angle of the cutting edge is much more obtuse and therfore it is stronger and resists chiping better.
a combination of converting to a york pitch and wetting the surface should get you very good results.
Robin
Re: convert your lunchbox to a York pitch
Barry Rubenstein
>Thanks for the info guys. I'll try a well tuned hand plane next. Stay tuned.
Barry Rubenstein
>Took a lot of work but the handplane did the job very nicely, followed by scraper.
