Veritas - Innovation in Tools
OT - Briggs and Stratton ignition
>I've got an industrial/commercial Briggs and Stratton 8 hp motor, on which the ignition seems to have stopped igniting. I haven't opened it up yet, but, from the graphics, I suspect it's points ignition. Do all the B&S motors use the same points, or do the commercial ones use something different?
Re: OT - Briggs and Stratton ignition
Jason Roehl in Lafayette, IN
>If it has points, there is probably an electronic replacement. Get the replacement...points are junk.
Jason
Gene Gauss
>I have a log splitter with an 11HP B&S engine. The points would go bad each summer while it was being stored. Sometimes the mice helped. I replaced the points and condenser ignition with an electronic unit last fall. It was about $45, and bolted on without having to remove the flywheel. Just cut the wire to the old points and condenser and install the electronic.
