Gun Cabinet Lock
Gun Cabinet Lock
Gun Cabinet Lock
Bob Boswood
>I have built a Gun Cabinet for a friend and we are looking for a more secure locking mechanism than what I was planning on. The cabinet has two glass doors of frame and panel construction. I was hoping to find a cam lock type of lock with rods that secure both top and bottom of doors sort of like on truck topper doors. Any advice would help. Thanks.
Bobin AK.
Re: Gun Cabinet Lock
They make such locks
Ellis Walentine, Host
>I've used them on French doors. You twist a central knob and it drives strikes into the top jamb and the floor. In the case of a gun cabinet, you might want to customize the scale and look of the hardware to suit the cabinet. I'll leave it to you to do the googling.
I've always been partial to secret mechanisms, including electromagnets. You could put a couple serious electromagnets into the case, running off of a 12-v transformer. Put a secret microswitch somewhere on the cabinet or elsewhere in the room and nobody would know how to open the cabinet.
Re: They make such locks
Fred Davis
>Glass paneled doors are pretty and display your firearms for all to see and invite burglars to smash and grab ,thereby making any lock system ineffective.
FredD
Kid factor
Ken Bellock (Houston, TX)
>A theif may just smash and grab, but kids can be real clever, and not leave a trace until they get hurt.
When I was little, a best friend of mine's father had a nice gun cabinet in their basement with a big lock on it. I can't remember how many times we broke into that thing. The hinges for the door had the screws on the outside, so we just removed screws from the hinges and opened the cabinet from that side. Thankfully we never got hurt, even with all the stupid stuff we did after getting into that cabinet!
As a side note... it's really hard to hit sunfish with a 357 magnum, even at a range of 3 feet...
Trigger locks? *LINK*
>Like the other's have said, glass won't stop thieves, hinges won't stop kids.
I wonder if these would help.... protect kids at least.
Happy Woodworking!
http://www.amazon.com/Master-Lock-90TRISPT-Gun-3-P
exactly Fred.
>I would put a simple lock to keep kids out but it's a total waste of time for burglars. Even solid doors don't work. My guns are in hidden, locked storage so they have to find them first and then break in. It's worked twice, they didn't find the guns but took lots of other stuff.
Burglar Resistant Glazing
Robby Wright
>A good glass store can cut UL listed burglar resistant glazing to fit your cabinet. They even make a version that has glass laminated over the resistant core for longer wear. Install this in a strong frame and all your going to give the snatch-and-grab burglar is a sore hand.
Robby Wright
San Marcos, CA
Re: Gun Cabinet Lock *LINK*
Randy
>Here is one I have used:
http://www.cabinetmakerssupply.com/wardrobe_lock_cabinet_misc._3454_prd1.htm
Re: Trigger locks?
Dan Donaldson
>Those types of locks (like in the photo) only work on certain types of firearms. That type won't work at all on my 1911 and I would not put one on others because of the damage potential to the finish.
How about mortise locks top and bottom?
John in NM
>If you can't find a single bar lock? That would probably be the route I would take. I also agree though, that you can't beat stealth!
Not exactly Herr Webmeister. Its called...........
Art Silva
>Breakin' zie die glass!!!!!
Fred Davis
>Bob ,
my first response probably didn't help you and then on rethinking the security aspect of your cabinet , I remembered that a lot of gun and pawn shops run a wire cable though the trigger guard of the guns in a row and lock that cable.
FredD
Make your own.
Lee Schierer - McKean, PA
>Years ago, when my Dad wanted to build his gun cabinet, he couldn't find any nice brass hardware to accent the cabinet. His solution was to make his own. He used some 30 caliber full metal jacket bullets, brass casings, brass rod and some brass plate to make his own locking door latches. He also brazed two shell casings tail to tail to make the drawer pulls.
The larger brass bosses are the bottoms of 50 Caliber bullet casings.
Lee
Bob Boswood
>Thanks for all the help, sorry I have not responded to the suggestions. Right after posting I went snow machining in the mountains. I think there is definitely a solution for me in the replies. The wardrobe lock looks a lot like what I am looking for. I figured if I had to I could make my own, but I never would have thought to use actual bullets as part of the hardware. I will run it past the owner and see if he wants to go that route he is pretty handy with metal fab. This media is really helpful and much appreciated.
Bob in AK.
Thats pretty neat!
John in NM
