Cutting Aluminum
Cutting Aluminum
Cutting Aluminum
Sawman
>I am making up a slot mortiser and am using aluminum parts for linear motion from 80/20,Inc.
I wll need to be cutting the extrusions down to size. Some of the parts are 1/4" thick. Anyone use a power mitre box?
Also anyone have experience with 80/20 components?
Re: Cutting Aluminum
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Yes, You can cut aluminum with a miter saw. I sometime use the TS with a sled, and even in a hand-held circular saw. If you have a low hook angle, triple chip, that would be a good choice.
I have not used that source, but thanks for the link
Pete in Holland, MI
>0 or negative hook sharp blade. Glasses & maybe a face shield are a must!
And GOOD hearing protection, it'll scream
Dave Bair, Eaton Rapids, MI
