200+ woodworking book reviews
question on framing rock
Bill Tindall, E.TN
>I need to make a table (coffee table sized) for a covered porch (to eat from). The main surface will be composed of two 18 x 18" pieces (18 x 36 total) of 1/4" thick marble. While it will not be out in the weather it will be exposed to outside and hence relative humidity and temperature swings.
Will this design work without busting the corner joints? Make a splined mitered frame. Rabbit out the inside edge 1/4" deep and drop in the marble. (Like an upside down picture frame with the marble flush with the frame surface). Caulk the joint/gap between marble and wood with something, what?
If not, what option do I have for framing the marble slice with wood to make a table top? Anybody go a picture of an example?
Re: question on framing rock
steve mackay
>Personaly (and I am NO authority but I have delt with surface plates) I think I'd build metal frames like the ones sold for surface plates then frame with wood. I'd be paranoid that, one of these days, I'd walk outside and the wood had given way and I had a granite jigsaw puzzle. But then, I'm an over-kill kinda guy.
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>I would not choose a miter joint for outside if it were me. I would do a M&T or slip joint.
As for setting the stone in a rabbit, that should work fine. I would leave a large gap then mask the face with tape. Then fill the gap with something flexible and rubber like, fingering it in while wet, then pealing the tape.
If you are set on the miter, you could get away with it by leaving a large gap and bridging it with the same caulk. Something like 3M 5200 will really stick and stretch with movement.
>I'd be inclined to let the marble float loose in the rebate with a bit of a gap around the perimeter, maybe 1/16". And supports under the tiles at the mid points and where they come together, across the width of the table.
Here's a design I came up with to display Cape Cod beach rocks.
Clint
Bill Earl
>This table is made from a slab of petrified teak set into a mahogany frame. The frame is mitered and joined with loose tenons. A piece of 1/2" birch ply is set into the bottom. The stone is set in from the top in a generous bead of silicone and the gap filled with sanded caulk.
BTDT
>Did a 24x48 kitchen bar-height table for my son's NY studio apartment. I used 12x12 Dark Emperador marble tile over a piece of 3/4 MDF. Stones were tight-set in a very thin layer of vinyl adhesive and clamped in a sandwich to insure a straight flat surface. I then framed the top with 3/4" walnut with mitered corners that was glued to the top with biscuits into the MDF. After several days for all the glues to dry, I filled the joints between the stones and the hairline around the perimeter with epoxy tinted to match the marble. Last thing was to champfer the top edge to a 45� leaving about 1/8" of wood protecting the outside edges of the stone. Support is a walnut frame with "standard" stretchers held on with screw blocks (2 to a side) glued to the MDF to fix the top.
Came through a fire in his apartment relatively unscathed. Remember that marble, being calcium carbonate, is sensitive to some acids, especially acid rain (and "fire water"), so if your stone has a polished surface you want to keep, keep it sheltered from precip.
question
Bill Tindall, E.TN
>Ahaa. That is exactly the answer I was looking for. Tell me more about what "sanded caulk" is for that sounds like what I need to fill the gap. Because we will have food (and spills) on the table I need the edge gap sealed to some extent.
I am also curious about how one gets the nice piece of rock. 30 years ago slabs of AZ wood were readily available but I was too poor to buy one then. It would have been a good investment. .
question
Bill Tindall, E.TN
>Was the epoxy tinted with a colored filler or some sort of dye? How did you get it in the cracks without getting it on the tile? I find epoxy to be like honey. Every time I use it it gets everywhere.
clever idea
Bill Tindall, E.TN
>I'll use it for another application.
Answer
>I used Transtint dyes (Homestead) because I wanted to be able to have some depth to the color like the Emperador stone. If you marble is white or any of the lighter colors, you'll need to work with pigments to body-up the base, then tint back with micro amounts of dye as needed. The stone surface was given a good coat of paste wax, then masked off beyond 1/4" from the joints. Lastly a light application of green poly vinyl alcohol resist was applied to the wax on the exposed surfaces.
You can't help getting goop on the top surface, but the wax + PVA lets the cured plastic come right off. A good alcohol rub removes the wax and you're left with a perfectly clean joint. Note here that you might be tempted to use acetone or other solvent to clean off the resin. DON'T go there as the solvent will attack the filler put on by the quarry leaving you with dull patches that will have to be repolished by a marble pro using special materials. DAMHIKT
THAT looks pretty "beefy" !
steve mackay
