gluing up boards
gluing up boards
gluing up boards
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I want to glue up four boards 6 in wide and about 2 1/2 feet long to make a rectangle about 2 feet x 2 1/2 feet . I've done it for boards about 3/4 inch thick or thicker, but in this case, the final rectangle must be only 3/8 inch thick; so I'm a bit worried that that's too thin to hold well. Any suggestions? My only thought is to start with thicker boards and leave thickness at the join edges but remove wood elsewhere -- say with a router -- to get most of the rectangle down to 3/8 in thick. (It's all right if parts of the underside of the final table are thicker than 3/8.)
Re: gluing up boards
Doug in Denver
>You should have no problem gluing up 3/8 inch boards. I've done 1/4" with no problem. Your suggestion of leaving it thicker only at the glue lines would probably weaknen it - it would make lines where forces would concentrate for easier cracking.
Joseph Mulherin, Sr
>I agree with Doug, you can glue up these boards. Just do not put too much pressure on the clamps when you tighten. Use four clamps...two below and two above...just snug them till glue just starts to ooze out of joints. Do not wipe glue off, let it setup and scrape off with a paint scrapper or trowel blade, then sand with ROS. After sanding use a sanding sealer before applying any stains, etc.
I've Done It Many Times
>Good Afternoon Eliot,
I've done boards down to a couple 16th inch with no problems. Do a couple of the 3/8 inch boards at a time, and then glue up the assemblies. Flatten with a sander. You don't need excessive clamp pressure.
George
Lee Schierer - McKean, PA
>The 3/8 thick glue up will be just as strong as any other glue up. When clamping, too much pressure will crush teh edges of the boards next to the clamps and bow the boards much easier than a 3/4" thick glue up. Putting clamps alterantely top and bottom across the glue up will reduce the bowing and help hold things flat. Tighten the clamps just enough to see beads of glue squeezing out of the joints.
Lee
It will work just fine *LINK*
Bricofleur
>Eliot,
As mentionned by the others, clamp pressure is important as well as placement. You may use cauls to prevent the boards from bowing. Glue both sides of the joint too.
If you want to read more on this, check this link.
Best,
Serge
Glue - Clamping Pressure
Jim Dillon
>Eliot,
You should have no problem at all. If you don't have a couple of cauls, as Serge suggested, try a couple of small blocks of scrap wood held in place with a 6 inch clamp at the end of each seam. Wrap the scrap wood with cellophane tape, or wax paper to prevent the glue from sticking. Once you have everything clamped up, you can remove each end clamp, wipe any excess glue, then reclamp. I keep a box of these scrap blocks wrapped with cellophane tape for something just like you are doing. And like others have said, focus on keeping everything flat, and little clamp pressure will be needed. Have at it.
Jim
Here's a way to do it without clamps
Ellis Walentine, Host
>Thickness your pieces down to just over their final thickness and rip them to equal widths. Then make a clamping bed from a piece of plywood with a couple stops (strips of wood) tacked or screwed onto it, parallel and about 1/16" closer than the combined width of two of your pieces. Brush a bead of glue onto the glue edges, then stand the two pieces with their back edges against the stops and their glued edges touching. To clamp them, just push down on the glued edges and hold them down to the plywood with a weight of some sort. You need to either wax the plywood or put a strip of wax paper down under the glue line to keep it from sticking.
Repeat this procedure for the second pair of panels and, for the final glue up, move the stops to the appropriate distance apart. Instrument makers do this routinely with bookmatched faces that are less than 3/32" thick.
steve mackay
>The thickness is no-sweat BUT I always glue such things with slats underneath (or on top . . . wichever) . Of course I remove them later but they make things go oh-so-much easier and prevent warp & twist during the glueing proccess.
>David Marks routinely did it by holding the pieces down with bricks he had wrapped in plastic and duct tape. Actually, he was gluing much thinner pieces.
>Thanks all for you help. It appears that gluing up 3/8 inch is really not much different form doing it with thicker boards. Thanks again, I needed the encouragement.
