"machining" copper
"machining" copper
"machining" copper
Howard in Bethesda
>�Machining� copper
Can I use a router and template to cut a 6 inch diameter disk from sheet copper?
If so any precautions I need to take?
The copper is Soft (annealed) to 1/8 Hard (H00) Temper and 0.043 inches thick.
Thanks
Howard
Re: "machining" copper
Bill Tindall, E.TN
>I don't know but be wary trying it. Copper is difficult to machine on a lathe (I have watched machine shop people do it but not done it myself) It tends to "stick" to the tooling. Sticking to tooling and routing at 18000 rpm could be a problem. Until I had a feel of how it was going I would arrange to take a very small trial cut. An alternative would be to band saw approximate shape and sand or file to final shape.
Yes, but sandwiched.
Bricofleur
>It can be done but sandwich your cupper between two 1/4" layers of plywood, MDF or hardboard with double sided carpet tape. Use a 1/4" carbide bit, of course, at the same speed as you would with any wood. Use a template and feed to the right as you are routing the exterior of your disk.
Copper, brass and aluminum are soft materials and can be milled with woodworking tools. I remember having cut aluminum sheets with a circular saw and a 200 teeth non carbide blade, but mounted backward on the saw.
Best,
Serge
www.atelierdubricoleur.spaces.live.com
>Personally, I'd sandwich it between 3/4" MDF rounds cut to about 1/4" more than the finished diameter, then mount the sandwich on a lathe between centers and trim the sandwich perfectly round to the final diameter. Double-faced tape and mentioned to make the sandwich. Depending on the diameter, 1,000-1,400 rpm should do nicely for a smooth cut.
You might also talk to some metal spinners to ask how they do it.
Of course, if you don't have a lathe . . . |;-{{
Did I mention I invented metal spinning?
>I heard such a thing was possible. Turned a disc of hard wood with a saucer like depression in it. Nailed a sheet of copper over it, with lots of nails around the edges. Used the head of a carriage bolt to press the copper into the form. Cut the rim clean with my trusty skew. Tip down, scored it. Cut a matching depression into the top of a little cherry candle stand. Made two. One holds a candle and one has a plant in it.
>You can also cut copper (or other non-ferrous metal) on a bandsaw made for cutting wood. I've turned it on a lathe as well. If you need a perfect circle with a smooth edge, you could even sandwich a roughly cut circle between two pieces of wood, friction clamp with the lathe tailstock, and turn round with a gouge. (Wear a face shield!)
Cut metal on a wood bandsaw?
Tom MacGregor
>I've made fixtures using aluminum up to 1/2" thick with a carbide blade in a tablesaw, but would like to be able to use my 14" Grizzly bandsaw. Can anyone recommend a proper blade? Will the high fpm be an issue? I'm assuming it would only work for non-ferrous metals unless I had a way to slow it down.
Re: Cut metal on a wood bandsaw?
Bill Tindall, E.TN
>I cut aluminum frequently with what ever blade happens to be in the saw though 4 tpi on thin sheet makes a lot of noise- 6 tpi is better. Don't try it on something that can friction harden though or the band saw teeth will become nubs in short order.
>I cut dozens of pieces of 1/2" copper pipe on my 14 band saw with what ever blade happened to be on it, but I think more TPI is better. Not sure I would be eager to do it again. The "sawdust" or filings were very sharp and tended to get embedded in the tires. Took a while to clean up. Also not sure it's a good idea to run your dust collection while sawing metal. Might be a chance of a spark or a hot filing getting into the drum. (I am truly not sure whether the filings are hot enough to cause a fire or not, just throwing that out there out of an abundance of caution.)
The saw did a good job, but it was a messy clean up.
Yes and yes...
John in NM
>The first shop I worked for did a lot of this sort of thing with copper and aluminum, so I know it can be done and is fairly straight forward.
Precautions:
1. Sandwiching helps a lot, preferably use a flush trim bit as you get these horrible burrs on the edges due to copper being ductile and metallicly "sticky".
2. Ear, eye, and skin protection. Chips are horribly sharp, tend to get very hot, they go EVERYWHERE (including over your head and down behind your collar), and the sound is absolutely awful! Routing a channel in some thick aluminum was even worse on all three counts.
So I recommend buttoning up your collar and long sleeves, wearing leather gloves with rubber bands around the wrists, earplugs and muffs, eyeglasses and a face sheild if you have one, and some kind of cap. Sounds overboard, but that's roughly what I used to do.
3. Rough cutting the piece to within ~1/8" over will help a lot. You can run a metal blade at wood speeds on a bandsaw and cut everything but steel. You can even make short cuts in steel if you don't need the blade to survive long.
4. Post pictures for us!!! :)
Just kidding !!!
Bricofleur
>Since it's that messy, why not asking that brother-in-law you hate so much to do the job for you !
Ha! Ha! Ha!
Best,
Serge
Need to do the Tom Sawyer...
John in NM
>Convince him how much fun it is, and get him to pay you for the privilege!
