tire sizing way OT
tire sizing way OT
tire sizing way OT
Sid Krogstad
>I would like to change tires and wheels from 215-55-17 to a 16" wheel and tire.
What would the combination be?
Re: tire sizing way OT
GalenV in Iowa
>You did not say what vehical you are changing the rims and tires on.
Look in your owners manual as they will generally give you alternat tires sizes that will fit your vehical. If you cannot find it go to a tire shop and ask them to look it up for your vehical. You need to know the smaller rim will fit over the brake and associated fittings. You will also need to know what the hub offset is so the tire is properly centered in the wheel well and will not hit any part of the car based on the suspension travel. You can sometimes go to a smaller rim and a higher profile tire so that it does not effect your speedometer reading.
I suggest you take your question to people who know what to check for and can see what you are dealing with.
Galen
Nat Robison
>It depends on how wide the 16" wheel is. Depending on the width of the wheel, you might still be able to get a 215-width tire. It looks like most 16" wheels are either 6.5" or 7" wide.
John McGaw
>While there may not be an infinite number of answers to your question there are certainly are a number of them. For example, you could use 215-60-16 tires. This would give a circumference of 82.18 vs. a circumference of 82.66 for the original tire which will throw your speedometer reading off by about 0.6%. Or you could consider a 235-55-16 giving a circumference of 82.24 which is even closer. Or a 290-45-16 which will surely demand some very special wheels (and likely some body modifications) but will be even closer.
Of course, not knowing how wide a tire will fit your vehicle, what sort of wheels you want to use, whether you even care if your speedometer is still accurate after the change any speculation is useless. If you care to provide that information a better estimation can be made.
Meant to respond to Sid
Mark Nowicki
>I H A T E T H I S F O R U M F O R M A T
Mark
