Another approach
Grant in Iowa
>Howard,
While I can't tell you where to get the cup and ball speaker grille catches, I can tell you about what I have done.
I have used rare earth magnets in cups to hold speaker grilles in place with great results. Since there are magnets on all four sides, they actually hold the grille in a "force field" so they actually hover in place. While the pictured ones are were flush mounted within a frame, you could use them to surface mount a grille on an enclosure. Maybe add some rubber bumpers on each corner of the grille for rattle resistance.
And while we are on the subject, I have figured out a way to secure the grille cloth seamlessly. I cut a 1/8" saw kerf about 1/2" from the inside edge and on the back of the frame stock before I assemble the frame. Once the frame is assembled, and similar to how you install window screen with a noodle, I use 18AWG stranded (automotive type) electrical wire as a classy looking noodle to install the grille cloth just like a screen. Trim the excess cloth with a sharp knife for a nice look and secure fit. This approach actually results in a recessed cloth look, or you could stretch the cloth over the front of a rounded over frame and use the same attachment technique for a classic speaker grille look.
In the attached photo, note the cloth is flush with the outer frame. This look is done by using an inner frame within the visible outer frame. The saw kerf and wire are hidden between the inner and outer frame.
Clear as mud?
Regards,
Grant in Iowa
