Not done but gettng there...
John in NM
>Finally got the utility closet door put on (its the lighter one, not oiled yet) last week. I'm leaning towards a discrete pull of some kind and ball catches instead of a knob. The doors on either side of the paneling will be obvious doors but I wanted to keep the closet low profile (any suggestions would be welcome!). Eventually there will be base board moulding, a sort of crown molding hiding a rope light, a wide chair rail type of molding and trim around the panels.
Re: Not done but gettng there...
Chris Knob
>Beautiful work John. Congrats
Hmm, low key, eh?
Ellis Walentine, Host
>How about Soss hinges instead of those butts? And how about using ball or roller catches as you suggested, but instead of routing a recessed finger pull, inlay a piece of iron somewhere in the closing stile -- probably at the intersection of the stile and middle rail -- and make a little portable handle of some sort with a strong magnet in it. To open the door, you'd put the handle against the wood where the hidden iron is located and pull. It would act like a key, too, because, when you take the handle away, there would be no obvious way to open the door. You could make a special little shelf or hook and store the handle as a little bit of a sculptural wall piece nearby.
Worth exactly what you paid for it, but you asked. :-) Nice looking doors, by the way.
Beautiful!
Tony - Memphis
Thanks!
John in NM
nice thought Ellis, but...
Gary
>If the utility closet has mechanical equipment, electrical or water shut-offs, I would not recommend your idea. Any emergency responder may need to access these, without the homeowner by their side. Without an obvious way to enter the door, they would be unable to secure those utilities,
it's just a thought (from a fireman), but I'd hate to see that ever happen.
Re: nice thought Ellis, but...
>I thought that was what a fire ax was for. |;-}}
Andy Lincoln,In Dearborn,MI
>John,
That is a real nice looking set of doors/panelling.What about using a
couple magnetic touch latches similar to the ones used on glass doors in entertainment centers??You could push in slightly on the door and the catch would then pop out to release the door.Off the top of my head(without any research at all) I'd look at McMaster-Carr and see if such a thing exists.
Andy
:0 !!!
John in NM
>Yep and axe would do it! That african mahogany is soft enough I don't think it would take more than 30 sec!
But for the record, the water and electrical shutoffs are elsewhere. This closet holds the water heater and various household items that you don't want often or visible.
I'd thought of trying to make it really invisible, but decided it was more a matter of "less than obvious". The doorway to the left is a bath, so I didn't want guests to be hurrying along and find themselves in a closet with a water heater. I do like the mag catch notion (further down), I'll have to look for some bigger ones.
Re: |;)
>The magnets do well, but you can also consider touch latches that you just push on to pop the door open. Have them for cab doors, but they come heavier for panels your size. Drawback is the door opens if somebody bumps it while walking past. The guy in the south end of the horse suit gets to walk into an open door.
