Pre-Finishing for Raised Panel Shrinkage
howard
>I went back to a customer for another project and looked at the entertainment unit I built 1 1/2 yrs ago. I see that the raised panels shrunk from the frames (made from solid maple). I have heard some talk of finishing the panels before assembling the door, but what are the corrrect steps - I spray lacquer, is the panel only stained, assembled, and then lacquered. If so, how to keep the panel clean (no glue getting on it, etc.) Does the panel get the seal coat to keep it clean or does it get lacquered? As you can see, I really could use guidance on the steps. Thanks for all your help.
Re: Pre-Finishing for Raised Panel Shrinkage
Ray Binnicker
>Hey,
When I do raised panels I do not put glue on the panels. I only glue the frame pieces. I do put stain, or oil if the product is only getting oil, on the edges of the panel prior to assembly. Any shrinkage that may occur down the road will not allow any bare wood to show.
Ray Binnicker
Lee Schierer - McKean, PA
>I generally apply satin and at least 2 coats of finish to the edges of the raised panels before assembly so that if the panel shrinks the color will be the same.
Lee
Lee - thanks, do you.................
howard
>prefinish the frame pieces also,or stain and finish after assembly?
Re: Lee - thanks, do you.................
>I finish the frames and usually the field of the panels after assembly. I forgot to mention that I also stain the inside eges of the frame pieces (panel groove side) prior to assembly since I don't want to apply stain to the already finished portions of the panel.
Lee
Jim Dillon
>Howard,
Agree with Ray and Lee. I prefinish, usually with a thin coat of blond dewaxed shellac, followed by several (2-3) coats of an oil/varnish (Tried & True). I've also done the same with tinted shellac as my first coat. Regardless, the entire panel is finished and allowed to dry for several days. I then assemble the panel and frame. To prevent vibration of the panel, I either peg it in the middle at both ends, or use "space-balls" or something similar. Sorta depends on how good the panel fits into the rail/stile groove. So far, I have not finished the frame first, or even the inside edge, but that could change if I were spraying, or if I was painting the frame a different color etc. I highly recommend prefinishing the panel. I prefinished 28 panels once in a large cabinet, and even after 5 years or so, I have never seen an exposed "unfinished" edge.
Jim
Sgian Dubh
>As you spray finish I'll use the example of a pre-cat lacquer, and recommend you do the following.
Apply one coat of polish to the panel and de-nib. Glue up the framework but don't glue in the panel. Mask off the panel and apply a coat of lacquer to the framework. Remove the masking from the panel and spray your final coat of lacquer over the lot. Two coats of lacquer is advisable; three coats of pre-cat each applied at a wet coat thickness of 4 to 5 mils is the limit to avoid cracking faults, which if bad enough are called Chinese writing.
If there is colouring up to do prior to polishing, eg, staining or dying, do this first to the panel, apply a seal coat and glue up the framework as before. Mask off the panel, colour up the framework, remove the masking tape, and apply your final coat of polish.
Adapt the general description just given for different film forming finishes, eg, nitro-cellulose lacquer, oil based varnish, shellac, etc. Slainte.
>As a hobbyist, I prefinished the panel, At least a coat or two of the final finish. If stain is to be used, I stain the panel, then apply one of more base coats. When I assemble the frame, I wrap the panel in thin polyethylene such as a dry cleaners bag and insert it into the frame. The poly keeps the glue from bonding to the panel if some leaks into the corners. The poly masks the panel while I catch the fram up. Most of the time I can just pull the poly out of the grooves, but it it is reluctant, I carefully cut it away with a razor knife. I learned the hard way not to use white trash bags for this. That little white edge is amazingly obvious.
I have a friend who is a professional cabinet maker. Made hundreds of raised panel doors. He stained the edges of the panels with a rag and then assembled them and stained the whole thing. At least the stain in the joint kept it from being obvious if the panel shrank. He buys his doors from a door company now. I will have to ask him what he does, if anything, since they come assembled.
Fred Davis
>Barry,
your Cabinetmaker friend was telling you right and I bet his approach is similar to mine which couldn't be simpler.
I always made sure the M.C. was 6% or in the case of this shop even less because of the way I built it.
Designing your projects with this approach eliminates any shrinkage issue and you need only to deal with expansion.
If your using material that shrinks enough to be noticeable on a raised panel door , I venture you wouldn't need to look far to see a glue joint that failed either.
Dry wood that started out with tight glue joints stays that way and planning for panel expansion is a lot easier then dealing with shrinkage after the fact.
So knowing this in advance should save you a lot of unnecessary steps in finishing.
Works for me and anybody that uses a moisture meter, dry shop environment etc.
FredD
