Boeshield then wax? (Ellis pls read)
Terry Alexander
>I ordered some Boesheild and some other things from Rockler using the link here. Q for Ellis...do we need to tell you so that you do "something" to get a cut or will you automatically be notified?
Q: about Boeshield. Yes..I am VERY anal about my TS. Even the slightest discoloration gets my immediate attention. (Just the way I am about my tools...and...yes....I use them a lot).
Have ordered Boeshield for the first time. Heard a lot about the product from this very forum. I have a few dark spots that I am hoping Boeshield will take care of. Do I then use my "normal" Johnson's paste wax or is Boeshield a cleaner and a wax all in one?
As always..TIA guys (and gals).
Terry Alexander in West Texas
Re: Boeshield then wax? (Ellis pls read)
Just order it
Ellis Walentine, Host
>Rockler is an esteemed advertiser, and they are probably watching how many click-throughs they get from their ads here on WoodCentral, so it probably helps us if you access their site through one of their links here. We are not on a royalty or affiliate program with them though, so just order whatever it is, and if you have a chance, tell them WoodCentral sent you.
Amazon is the one that pays us a percentage of any sales that originate here. Find their link on our home page and/or in the left hand column of this page.
Thanks for asking.
It took some looking around....
Terry Alexander
>....the home page, but I finally found the Amazon link.
Will use that next time.
Trying to be a good participant/patron ;-)
Terry Alexander
about Boeshield
Bill Tindall, E.TN
>It sounds like you expectations for Boeshield may not be met. I don't think it is a cleaner any more than any solvent based material including wax.
I use this stuff but I regard it as a storage coating. It leaves a sticky film (unless wiped off in which case I am not sure it will do the job) and I would not consider using it on an actively used tool surface. It does prevent rust in damp locations. I use it on the planer bed for the big machine that sits outside in the lumber shed. I have seen moisture condense on cold metal in this environment yet no rust forms on the bed.
Re: about Boeshield
Charlie Self
>I used Boeshield as a primary protector of cast iron table tops for over a decade. If you buff out the first coat, add a second coat, and then buff that out, you will have a protector at least as good as any floor wax...and a bit easier to apply. For long term protection, spray it on heavily and leave it. I stored a contractor's saw outdoors, in central Virginia, about 14-15 years ago, for two winters. (Basement was full, building a shop for which the saw was needed.) Covered with a good tarp--the blue blue plastic garbage--it was fine. Spray on a fresh coat come spring, and buff it out. Spring, summer and most of the fall the saw was left buffed out, with a tarp over part of a sheet of plywood as protection.
It's not a miracle protectant, but with care, it works.
I've never known it to pull out rust, though. There is a separate Boeshield product for that, or used to be. I believe that removes rust, but, AFAIK, the only real way to remove stains in cast iron is to machine them out--very, very fine (1000+ grit auto body paint stuff) sandpaper works as well as anything, I guess. I've tried it on small patches. I just don't like grinding away any metal that isn't a real problem.
The Amazon Link
>... is on this page, right under the "Sightings" banner.
Cheers,
Re: about Boeshield
Mark_in_Michigan
>When I first tried Boeshield, I used it as a lubricant with sandpaper to remove some light surface rust from my tablesaw (i.e. wet-sanding). I then wiped it off and applied another coat and buffed that out as well. I apply maybe one coat a year and never get any rust now, it does seem to prevent rust after buffing it off.
West Texas isn't exactly the Gulf Coast.
Victor P
>I use Johnsons Paste Was in Houston, and it works just fine.
Victor - Suffering from extreme levels of tree polen. (cough cough blow blow)
Got it...will use it first from here on..tks
Terry Alexander
Howard Acheson
>Boeshield T9 is a brand name of a family of metal cleaning and protectorant chemicals.
One is their "Rust and Corrosion Protection" and another is their "Rust and Stain Remover".
Used alone, the Rust and Corrosion Protection will not remove stains. For that, you need their Rust and Stain Remover. Once you have the metal cleaned, then apply the Rust and Corrosion Protection.
Rust free first than BoeshieldT-9
del schisler
>here is what you do Use Rust Free first This will remove rust spot's ect Than use the Boeshield T-9 The boeshield has a nice wax finish you can leve a lot on wipe a lot off Any way it works I have used this for a couple yrs now The only way to go Works very well del
the link that explain's about rust free Than order from amazon http://www.theruststore.com/Rust-Removers-C1.aspx
