THE WOODRAT IS BACK!
fastening a bolt
fastening a bolt
fastening a bolt
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I'm not sure I can communicate my issue well, but here goes: imagine an ordinary bolt -about 1/4 inch-- designed to hold a wooden board down against a metal bar. The metal bar is attached to a wheel chair and the board is basically a tray that will be put on the bar and taken off from time to time. The idea is to be able to take the tray off quickly and to be put back quickly without fussing with or loosing any kind of small nut or whatever, which would obviously be the ordinary way to attach things using a bolt. What I'm hoping for is some kind of thingy that can quickly fasten the tray to the bar, come off and go on easily(think of an elderly person with shaky hands an poor eyesight having to do it) , and not get lost falling down behind some piece of furniture or whatever. Any thoughts?
Re: fastening a bolt
No bolt at all *LINK*
Bricofleur
>How about using rare-earth magnet epoxied under the tray. There are different sizes, shapes and strengths available out there.
Best,
Serge
Lee Valley rare-earth magnets choices
Thats pretty good ! . . .
steve mackay
>Maybe even think up a way to use one of Mr. Lee's "release knob" magnet thingies.
Could you post a photo
Keith Newton------WebKitFormBoundaryV6MZb+tiOpocz6
>Of the arm of the chair? Is the tray to be large enough to hold a plate / meal, or just a drink?
I would think there should be something on the market already available.
I would be thinking of getting its bracing off the front leg of the chair, with a slot fitting over the arm, and maybe a velcro strap to hold it down.
I like the velcro idea
Ed Mulligan, Cape Cod
>Also like the magnet solution.
Also, there is the quick release pin:
http://www.pegasusautoracing.com/productselection.asp?Product=3050
They come in different diameters and lengths. You press on the button on top to unlock the little ball stops. There's a ring to which a string could be attached to keep the pin from getting lost.
Also, look into trailer hitch pins. They come in different sizes and might be suitable
Take a look at quarter turn fasteners *LINK*
Phil Joines Krum,Tx
>There are a lot of them
MSC
>Brilliant! I already ordered two -- and I got them with the on/off feature. So the lady's mother can easily turn the magnets on and off to easily take the tray on and off. Strangely, the Lee valley magnets, designed for cabinet doors, don't come with knobs; but I can certainly make two of those. Thanks for the great suggestion!
Re: fastening a bolt------WebKitFormBoundary+hxsYD
>Thank you all for the suggestions. I've decided to go with the on/off magnet solution in that it seems the easiest to use and there's nothing to possibly fall off.
------WebKitFormBoundary+hxsYDrKchjHzQlN
Re: Could you post a photo------WebKitFormBoundary
>You wouldn't believe how much trouble this lady has had already. Several professional cabinet makers apparently went running, pulling their hair out, when shown the situation. I don't really know her, except now I do, after working with her for a while -- only on weekends. Believe it or not, even though nearly totally paralyzed, she works every day as a social worker(supervisor yet!) I'm doing the job without payment, although her family is more than happy to pay for any wood. She has asked for solid wood -- not plywood -- which I will glue up from something nice like tiger maple. The tray has to be exactly made up with various cutouts for her arm and a joystick to fit in; and there is a speciality vertical rod with a pad on top that has to be exactly in the right horizontal and vertical position for her wrist to sit on when "driving" the chair(a $20.000.00 motorized one!) There are all kinds of bars and sliding stuff to work around. I find it a challenge, and I've made a good friend. I have been offered Champagne when the job is done!
------WebKitFormBoundary14UR+stxankAqeut
>By the way, I do know how to glue up boards to make a flat table( I suggested veneered plywood, but the lady wants solid wood.) Now I'm a bit uncertain about how thin the boards can be for a successful glue up. The tray can be only 3/8 inch thick in certain places. I could always use thicker boards and rout out wood on the under side, where I need the thickness to be 3/8, leaving the join edges where it's glued together thicker.
